Maggie Heartbeat C7 Stingray track time
Finally managed to round up a set of Drag Radials and get the Stingray to the track.
2015 C7 Stingray Z51 A8 - stock except:
Magnuson TVS 2300 Heartbeat at 8.5psi
LT4 HPDI fuel pump and injectors
2.5 gal of 109 added to 3/8 tank of 91
Mickey Thompson SS drag radials
Launched at idle with T/C off, touring mode, and transmission in D. No problem with traction but the track was so packed I couldn't get another pass in (notice timestamp)
Plenty of MPH for better ET, but it looks like I need more work on that launch.
Similar MPH to mine, but I could not 60'. My time was 11.1 at 131.50mph. That was with the stock lower pulley and standard 87mm upper pulley. Boost was 6.5psi. This was before my C7 had headers installed. No mods on the C7 besides the Magnuson HB2300 SC. I expect better ET and MPH with headers and the newly installed 78mm pulley which makes 8.5-9.0psi boost.
Am running an 85mm upper, not sure what the lower is - I'll have to measure. It is a dedicated drive on this one and the lower is bigger than the standard C7 crank pulley.
Just started running water injection on the dyno engine, looking forward to adding it to the car and bumping boost/timing more as soon as it's dialed in.
How good it the drivetrain in these cars? Don't see any transmission problems (other than tuning) but how about diff/axles?
Fore58 (01-30-2017)
204mm (8.03") lower and 85mm (3.35") upper for a drive ratio of 2.4 putting me right about 15,000RPM blower speed at the 6300 RPM shift points.
Running this same pulley arrangement on the engine dyno produced right at 700HP @6200RPM (50/50 mix of 109 and 91 octane fuel and Magnuson HPDI fuel pump).
When I ran 131.50mph, it was without headers and with the stock Magnuson pulley which made 6.5psi. On this combo, the rwhp was around 580rwhp on our Mustang MD250 chassis dyno. I have not been back to the track since recently adding the headers or 78mm pulley. Yes, I would expect the mph to be closer to 134-135mph with the current power.
The eforce moves roughly the same air with a 3.0 as did the 1.7 with a 2.38 (same lower)
