Track Tire Wear--is this looking about right?
bhk2 (07-20-2016)
bhk2 (07-20-2016)
Sr.Random input generator
Yep, it's normal. After driving at the street for a while, the wavy pattern should wear off, and it should look normal again.
bhk2 (07-20-2016)
Normal. Here are mine after 5 sessions at COTA. I had tons of pick up because they where running a Porsche Cup race the same day. Made for a fun 70 mile ride home.
bhk2 (07-20-2016)
On the photo of the rear tire there is a small arrow with the pointer near the tread wear line. That shows you that your pressure maybe slightly low because the wear is passing the point of the arrow, but ask someone running the track day. They usually are pretty knowledgeable about this stuff.
On the photo of the rear tire there is a small arrow with the pointer near the tread wear line. That shows you that your pressure maybe slightly low because the wear is passing the point of the arrow, but ask the someone running the track day. They usually are pretty knowledgeable about this stuff.
djnice (07-30-2016)
