Battery disconnect on which post?
I know this has been discussed before many times but I can't find the comments. I always put my green shut off, or my blade shut off on the negative side. My "new" 64 Riviera has it on the positive side. Any thoughts about what is best?
2018 C1 of Year Finalist
Negative on mine. Not that easy to get to. I think it does make a difference when it comes to spark and possibly fire. I was always told to disconnect ground.
Battery disconnect switch...
Alway the Negative terminal... the reason for this because as soon as you disconnect the negative terminal there is no way you can accidentally short the battery.
If you put the switch on the positive terminal, the battery negative terminal is still connected to the chassis of the car. So if anything conductive comes in contact with the positive terminal it will short the battery.
-Bruce
-Bruce
-Bruce
-Bruce
https://www.corvetteforum.com/forums...post1590159624
Negative side.
The battery posts are different sizes/diameters and most disconnects are made to best fit the negative post (which is thinner/smaller)
But either one will obviously work. Don't overthink it.
Larry
Larry
-Bruce
-Bruce
Looking back on my drag racing days, the NHRA requires the cut-off to be on the positive side. I still say it really doesn't matter though.
Sometimes its best to just follow a device's directions....and use a product as the manufacturer intended.
Like those in this 'green ****' installation document...
2016 C1 of Year Finalist
Bruce,
I agree and have all my green switches on the negative terminal of the battery.
Ron Francis Wiring recommends installing the battery disconnect on the positive terminal. They state that it is especially important on cars with electronic accessories or fuel injection.
Im not changing mine as they have worked for years with no problems.
Bruce B
Bruce B
Bruce,
Bruce B
Bruce B
Stay cool the next 4/5 days!
-Bruce
ohiovet (07-21-2016)
Bruce,
Bruce B
Bruce B
In broader (not absolute) electrical terms, wires & wire nuts that are green are ground.
I always assumed that was why the green disconnects were.....green.
I still say it really doesn't matter. Put them on which ever terminal has the easiest access.
I agree that the neg. terminal is best, but on my car I connected the cut off switch to the pos. terminal and mounted it right in the dash where the lighter goes. (who smokes any ways)
I did how ever instal a 16GA. fusible link directly to the batt. to protect the 10 GA. wire.
When I stop the car, I always shut off the switch before I get out. That way everything in the car is powered off except the alt. which I also installed a 16 GA. fuseable link in the circuit .
My shut off has a removable key, further protecting the car from thief..
We disconnect the battery for a different reason, so the negative side should be used for the cutoff switch.
Kerrmudgeon (07-22-2016)
That NRHA comment defies electrical physics. They must use some magical wiring system that keeps the battery in the circuit with the negative disconnected. That's assuming that disconnecting the positive in fact kills the engine.
