Would you install a Shark Bar and 5 point without roll bar?
Hello. I was wondering if anyone would install just a Shark Bar and 5 point harness without a roll bar. I'm not sure the support for the stock roof is safe in a roll over. I do mostly HPDE advanced group. Roll overs are rare at Sears Point, Sonoma Raceway, but I would like to be as safe as possible.
Thanks
Mike
2016 Z06 Z07 package. M7
Thanks
Mike
Prevailing opinion is that the Halo is strong enough in a rollover situation. That being said, there have been accidents where the Halo was struck by a thin solid object (sign post) it failed, but the driver was still ok.
I have one installed, but I end up just using the 3 points because of the stock seat sub belt setup, makes it kinda uncomfortable in the groin area.
Mamandoli (07-21-2016)
To directly answer your original question, no I wouldn't do one without the other. That being said, I'm very torn about installing a bar in my daily driver.
While not a C7, I have a C6 ZO6 and am considering a harness bar with the Scroth ASM Prof II harnesses. Since they don't hold the occupant upright in a crash, I would think they would be more like seat belts in a roll over: https://www.schrothracing.com/produc...fi-ii-asm#1597
Yes I would. There is no room for a proper bar in these cars without fully gutting them. The ones on market are a joke for road course use and are for hard parkers or maybe passing drag race tech.
I have a shark bar in my 2016 z,
No issues. I had one in my 09z.
I run twice a year at the Mojave
Magnum mile. In order to run A2
Class a harness is required. BTW a Z06 has a roll bar strength in the roof.
Received 8,928 Likes
A roll bar is next to useless because of the halo. If you want total roll over protection you need to install a cage. The danger isn't from the halo collapsing it is from the A pillars collapsing. When they bend upward into the passenger compartment they bring the front of the roof with them pushing the occupants heads upwards while their body weight is pushing them down. The roof shoves the head forward and into the chest. All of this can happen while the halo gets nothing more than a few scratches in the plastic covering.
Here is a C6Z that flipped right in front of me and my student back in 2010. It ran up the tire wall in Turn 6 at the Glen and then dropped about 4 feet onto its roof and pivoted around for a few seconds before coming to a stop. A large part of the left side damage occurred when they had to roll it over to get it on its wheels.
I run a Shark Bar, have the competition seats and use the Schroth Profi II ASM 4 point belt assemblies that reduce the chance of submarining under the lap belt. The advantage of these assemblies is you can add a 2 point sub belt that will attach at the same point the lap belts attach while the occupant sits on the sub belt. Schroth makes adapters that can be bolted to the stock lap belt mounting locations as does BK. I have the BK mounts in my car.
Bill
Bill
The following 2 users liked this post by Bill Dearborn:
Mamandoli (07-21-2016),
yellow1974 (09-18-2016)
Thank you.
I don't understand why submarining is such a concern with 4 point harnesses but not for a 3 point OEM belt. Aren't the lower two straps on a four point still low across your lap? I figure you could submarine in either.
The 3 point allows your body to fold over the lap belt. With a 4 point, the force is translated from the horizontal plane to the vertical and you submarine.
srshaw3 (09-23-2019)
Makes sense. So that Schroth system lets one shoulder fold over a bit and supposedly counteracts the submarining. Anyone crash and test it?
If you look at the linked page, you will see a photo where is shows that one side lengthens allowing your body to fold forward, this is what prevents your body from submarining under the lap belts as well. So, in a crash the lengthening of one side means your body is not held strictly upright.
Sure, not "strictly" upright, but the inboard shoulder harness only allows for a short amount of additional travel to allow the body to slightly pivot and plant the hips in the seat. The torso's forward movement is still greatly restricted. No comparison with the factory 3 pt.
I have the BK lap belt mounts and clip in end points on the Schroth lap belt ends. They just clip into the BK mounts which are bolted to the same point as the stock lap belt mounts are bolted to. This means the lap belts are fastened to a known strong points that have been crash test certified. The shoulder belts wrap around the harness bar which has not been certified but guesstimatted on how well it will perform. Neither the Shark Bar or BK harness bar have been certified in any sort of crash test so there is no way to know for certain how well they will hold up in a crash Vs the stock system, Vs a roll bar or a cage. Just like the roll bar and the cage you have to take the word of the manufacturers.
Here is the video showing the testing of the ASM belts.
I would recommend viewing the Schroth Training Videos developed by HMS Motorsports because they show a lot of information on how to properly mount belts no matter which brand you use.
Bill
arturox2 (07-23-2016)
Deciding how much to accept is a personal choice.
The Schroth harness provides a risk level that may be more acceptable to some than driving with standard harnesses, or even the regular seatbelts. For example, with a Schroth harness, I might retain control of the car rather than struggling with just the restraint of a seatbelt.
It is an individual choose your own risk level.
Yes, there is risk. HPDEs include inherit risk that are unnecessary. Choosing to participate is accepting risk.
Bill
Bill, that is a key point and another the reason why the Shcroth 4 pt is a safer option. It was a key factor in my decision to use this racing harness.
For those events where it's not accepted, I will use a Simpson Hybrid with factory seatbelts so I will still have head and neck restraint.
I often wondered if the ASM system would be as safe as a traditional harness with anti sub belt for multi hit accidents. Every video I've seen has shown a frontal impact type test. What about accidents that include more than one hit, secondary side impacts and multiple rollovers? I'm not sure I understand the ASM system well enough to confirm if after the initial impact and stretching of the inward shoulder harness, if the car is still flipping or rolling will the extra slack of the shoulder belt cause potentially more injuries?
I am making the assumption that once the inward shoulder belt stretches, it does not retract to its original length....in essence you end up with one shoulder belt much looser than the outward belt. Is this correct?
Good thread with a lot of good info.
Mamandoli (07-24-2016)
