Those who are pulling (crankcase pressure) from both valve covers
Getting ready to install a set of Holley valve covers....want to pull crankcase pressure of both banks. What (AN) fitting size are people using? Welded or tapped in?
1/2" barb welded. That way no fittings, or anything. Hose just pushes on.
Or DGAF.
Yes they are baffled but the baffles don't go the full length of the cover, so just don't be dumb like me. Drilled a hole to weld and then noticed it wasn't behind the baffle. So welded it shut, then move it over to behind the baffle.
I don't care about looks so this is my crap box.
No. Wouldn't be able to see anything anyways as it is under the baffle.
Billet tech offers a pinch more clearance.
Ground down the coil part until it fit. The boss for the coil hit the alt.
