[C2] Window Springs
Window Springs
I need new window springs in my 66....
How hard is it to wind these up and get the correct tension?
Power window regulator??? If it is... it is not a big deal because the spring only rotates about 3/4's of a full turn. The spring obviously is under tension to aid in raising the door glass...so it would be wise if that you get it secured in a vise so when to remove the motor AFTER you have placed a bolt in the linkage to hold it ( there will be a hole in the linkage arm and regulator housing that will line up for this)...so when you apply manual force to get your bolt out...you slowly release the tension and you will see the spring can ONLY go in one way.
DUB
DUB
Should have mentioned they are NOT power window's...
Is it the same process for manual?
A photo who help clear this 'fart' up.
DUB
Dont have photos as the 'scissors/regulators' still in door...
Thanks for the photo!!!
If this were in my shop. And knowing how much tension is on that spring. due to doing so many power window regulators which are basically the same principle.
I would crank the regulator so I could put a bolt in the large hole to the LEFT of the splined shaft on the realtor that you put your window crank handle on.
Then I would drill out the rivets that hold the splined crank handle shaft cover and remove it...which would free up the regulator main gear when it is removed. Then carefully remove the bolt I installed while at the same time keeping tension on the long arm of the regulator that has "LH' written on it in the photo. SLOWLY allow the long arm to swing and release the tension on the spring....put on a new spring...and then reverse the procedure.
I would then ...more than likely before I put the new spring back on.... figure out what type of fastener I would use to replace the tubular rivets I drilled out. I do know I would not use a regular blind pop rivet. I would either go back in with the correct tubular rivets due to have the rivet set to set them correctly...or stainless steel machine bolts and nuts.
DUB
DUB
66jack (07-24-2016)
DUB
DUB
After you put the 'bolt' in place to hold tension, why can't you remove spring with 'tool'?
I am sure there may be way around it...I was just giving the safe way so the spring does not fly out and do damage. This spring is NO JOKE...it is under a lot of tension.
DUB
Jack, here is a better picture of the spring, and a picture of a new spring. Getting the old one off would not be a problem, but it appears that the new spring would need one full revolution to wind it up. That would be difficult.
On the other hand, new springs are $26.00, but you can get a complete regulator for $100.00.
66jack (07-26-2016)
Thanks 'dub', 'buns'...for the pics and the process on installing the springs..
I do not think that is ONE full revolution...But I may be wrong...but I think I am correct...it is less that one full revolution.
More than likely it is about half +/- a revolution by how the new spring looks in relation to the spring that is still on the regulator.
DUB
DUB
