So, a guy pull up to back into a parking spot...
I attempted to take my girlfriend to breakfast this morning in the C6, and I pulled up to backing into a parking spot. When I attempted to shift into reverse, i continued to move forward. It was a good thing I was backing into a spot versus having already pulled in. It seems, my linkage has become disconnected. I have nothing but drive. The shifter feels like it is completely disconnected from anything. I have looked online and through this form, and apparently it could be at the transmission in the rear, or in the center console with a dry rotted bushing.
Suggestions on which end to check first?
The center console is alot easier to remove than the transmission so based entirely on that logic alone, i would start with the center console.
Same here. Question, is there any point in just replacing the top grommet if doing this as a preventative maintenance item? Seems to me like the bottom grommet will probably break soon if the top is ready to fail.
I will be doing this soon as a preventative move and would have no problem doing the top grommet but would probably have a pro replace the entire cable if both grommets are likely to have a similar life span. What do you all think?
having owned a C5 which I sold to "move" up to a C6 I cant believe the numerous , unnecessary part failures that these cars demonstrate. I have the original window sticker of my fully optioned 2005 vert that cost just under $92,000 CDN and this goes on and on and on!!!!
it truly is labour of love owning these things!!!
I've had them both go and fixed both. If you can easily jack the car up, check the bottom (rear) one first. If you can't, it's really easy to remove the center console and check under the shifter.
For what it's worth, the top end is a LOT easier to fix.
Race Car Tech
I have purchased the bushings and will replace both during the winter hibernation period. My C6 has over 80K miles on it, and 10 years, so I think it's time for a bit of preventive maintenance on those particular items.
Thanks for the advice and support guys. I was planning on removing the center console to facilitate replacing the cabin carpet. Guess this moves that particular activity up the list of priorities a bit...as in all the way to the top. I will post back as to the cause and pics.
Check the rear first because you can see it from underneath the rear of the car without any disassembly. BUT, it is very more probable that it is the front grommet because of the heat trapped inside the console tunnel. Not many members here have reported rear grommets failing.
check rear first i've replace both of mine within a year and my as well. mine an 07 his 09.
I just finished installing a whole new shift cable because I wasn't careful.
Be careful putting a new bushing on under the console, because that cable linkage plastic guide shaft is very fragile. I broke mine while installing a new bushing. I lifted the linkage too high, and it snapped.
Remove the four bolts that hold the shifter in place, it's under there.
so...maybe my girlfriend is correct. Just maybe I am a tad bit stubborn. So, all you fine folks said "check the rear first because it is the simplest to check." Well, me in my infinite laziness did not want to go to the storage room to get my floor jack to check the rear. Since most everyone says it is the console bushing that fails most often I proceed to disassemble the interior...only to find the console end is perfectly connected. Now heres hoping I did not lift it too far up and break something just to see all is well under there. Guess tomorrow I will be jacking up the rear and locating that connection point.
AMEN to that rose. Heck....I've already stopped ever putting it in park when waiting at a drive through......try and park where I can pull straight out of a parking spot as opposed to backing up.....etc....etc. Call it paranoia if you want....but ain't nothing worse than breaking down in a REALLY BAD spot and having to let your ride sit in a really bad place while waiting for a wrecker. Then watching all the people laughing at the poor B@#$%&D with the Corvette that won't work....LOL.....Thanks GM...
Well...it was definitely disconnected at the transmission. Looks like I am going to be dropping the exhaust to have enough room to change the bushing. However, I am purchasing a sweet sounding modified NPP exhaust this weekend so I am guessing I can perform both operations at the same time.
Way to turn a fail into a win!
