C7 track package $1500
I sold my Z51, and won't get a Grand Sport until the spring. I am selling my track package. Wheels and tires will fit any C7 base or Z51. Brakes fit Z51 calipers only. TSW Interlagos wheels in 18x9 front and 18x10.5 rear with Yokohama Advan racing slicks 250/650 front and 280/680 rears (endurance compound) with 8 heat cycles. 4/32" rubber still on tires, which should be good for 3 more weekends. Same exact stagger as OEM rubber, so all stability and traction control settings work perfectly. Wheels are in excellent condition...no chips or scratches...just what you'd expect with 250 miles on them. GM tire pressure sensors are installed, so all pressure and temperatures display on dash. DBA T3 rotors and Carbotech pads (12 front and 10 rear), though you will want a new set of fronts, as the fronts are 50% worn. Rears are only 15% worn, and should be good for several weekends. Rotors are in good condition, and should last through 3 or 4 sets of pads. 50 feet of heat wrap to wrap your exhaust pipes around the transmission, along with 4 clamps to hold in place. Front and rear tow hooks to fit all Z51's produced after November 2015. The only thing left to buy is 2 jugs of Mobil 1 15W-50 from WalMart and a liter of Motul 600 brake fluid. Use the GM track alignment, and swap all the parts: Now your C7 is ready to turn hot laps without tearing up your street parts. Shipping and PayPal fees are additional. I can deliver to COTA or Harris Hill. $1500 firm.
Danno
My only concern is that the wheels fit my Z51, as the TSW website doesn't seem to think so. The TSW site recommends 19", but doesn't suggest the 18". If you've been using them without issue, I'll happily take your word for it.
I'm actually interested in the wheels and tires, as well as the wrap, if you are willing to split it up. I see a plan coming together here.
$1200 picked up (or delivered to a local race track, like COTA). If we need to ship, buyer will pay actual cost. I prefer the pickup or track delivery. Schedule a track day at COTA, and come on down to Austin!
Are the tires good for 1/4 racing or only track lookin to get them for drag racing
These are road racing slicks. I expect the sidewalls are too stiff for a good drag racing tire. You would not need all four wheels for drag racing, so you can buy two TSW 18x10.5 rear wheels and add a set of drag radials. That would be cheaper than buying 4 wheels and tires. Good luck!
The rotors don't let air in from the backside (which I didn't know until I looked). I have attached a picture. I did not have any issues with the brakes, once I learned where the limits were. I looked at other C7 Z51 rotors while at the track. Based on the wear, DBA uses a higher quality steel than the OEM rotors. I was able to brake at 250m in Turn 12 at COTA lap after lap, turning 2:36 laps. I did some qualifying type laps, using 15-20% less road for all braking points, but this was not repeatable for more than two laps. This is exactly how every other production based race car has reacted to qualifying pace. Folks, don't try this at home! When I was racing professionally, I would alternate qualifying laps with a 95% pace lap in between. This would allow me to find at least a second a lap (sometimes two seconds) without tearing up the equipment.
I do not have a picture directly from behind the car, but do have this 3/4 view. The tires and wheels don't stick out from the side of the car. The tires do not hit the bodywork, regardless of body roll or bump travel. I had the height adjusters set on minimum height, and pulled 1.6g's through the Turn 16-18 complex. If there was a clearance problem, it would have manifested itself there.
VADanno (08-06-2016)
Everything but the tow hooks has been sold to Matt, so he can hook up all the power from his twin turbo C7 during hill climbs and track days. Have fun, Matt!
