Changed out shifter and now C6 won't start
I changed out the shifter on my C6. Now it won't start. Message said "shift to park" when I try to start it. Ended up disconnecting battery so it wouldn't run down over night.
This morning hooked battery back up and tried to start it, wouldn't start. That message is gone, and I can shift to all gears, but it won't start.
I have lights and radio, but just won't start.
Any ideas?
Any ideas?
You sifter linkage might be out of adjustment. I had the same thing happen when chnaging out my exhaust.
Any ideas?
Any ideas?
Lori New (07-24-2016)
Auto trans,
If so, then check the switch on the front of the shifter assembly that the shaft will bump closed when you are shift to part.
Here is baby, and so make sure that the shifter is pushing it's arm iforward, and that it making a continuity connection, and it plugged in.
Hence on a used one, some times you have to bend the arm a little more open, so when the shifter is shifted to park, it activating the switch. If the switch is really old, then you may have to pull it apart to clean it contact points isntead.
As for the car to start, the park switch has to be pressed in so it sending continuity through it, and your foot needs to be on the brake pedal to activate that switch as well.
As for the brake pedal position switch, it has no a manual adjustments , but is calibrated for the pedal position when the switch is installed to the car isntead (read takes a Tech II tool to calibrate the brake pedal switch).
Auto trans,
I appreciate the quick response. It was a brand new unit from the chevy dealer, thought it was plug and play. Still says shift to park and will not start.
Any other ideas?
If you are in park, then the car is telling you to shift to park still, then either the park switch is bad, you forget to plug the connector in, or there is bad wiring between the switch and its main connector.
Just disconnect the main harness connector, and with the shifter in park, check the park switch wires connector pin to make sure you have continuity through them. If you don't, then push the park switch arm forward more, and see if that solves the problem of not having continuity. If still not continuity through the connector pins, then bad wiring or bad switch.
Hence that park switch, is the only thing telling the ECM if the shifter is in park or not!!!!
It's also possible the button on top of the shift **** is not springing back up all the way after you push it in to move the shifter. If that happens it will think your not in park. I had it happen when I switched shift *****.
Its not just the shifter that needs to see it is in Park. Transmission needs to be in Park or Neutral itself.I'm betting when you changed the shifter you pulled up too far on the shift cable when disconnecting it from the shifter. You either broke the cable at the fwd bracket or its been pulled out of rig.
Disconnect cable from the shifter again. then Get under the car and rotate the shift arm on the trans all the way aft(count the detents as you rotate the arm) verifing the trans is in Park.
then with electronics only connect to the shifter see if itll start.
Its common for the cable to break when changing the sshifter. search other threads in this section on it
I just finished installing a new shift cable in my 05. I accidentally broke the old one while replacing the bushing/grommet. I lifted the cable linkage too high and it snapped.
PM me if you need help and I will try to walk you through it over the phone.
Very good advice. The shift position at the center console must match the shift position at the tranny. So, even if you shift it into park and the "shift to park" message goes away, and it still won't start, is because it is not really in park at the tranny end. Also, your battery may be weak.
Man I need help I also broke my cable trying to replace a bushing I got the new cable yesterday took out the old one it needed to be changed regardless it was old I successfully installed it everything was working fine manually shifted it I did it right but my car won't start my shifter is stuck in neutral and drive and it keeps saying shift to park
reviving an old thread....Basic issue is no start .. Have an 08 a6.. just swaped out the tranny.. During the swap my room mate wanted to help and at one point i had him put it in neutral.. I herd a few load bangs and welp he forced the shifter to move.. Got in the car when done and was stuck in N-D.. Search function helped out huge.. Pulled out the shifter breaking the cable but thats another issue lol.. Pulled back on the lock out tab and boom shifter operated as intended... Hooked it back up to the car without the cable(trans is in park)...Press break and solenoid unlocks shifter. Press start and solenoid locks shifter in park.. That seems great.. just need a cable but... it didn't start
Sorry its a ramble but frustrated right now
edit also did do post 3
