1/4 Mile Times
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
Yes, You're not going to run those times on stock tires.
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
Yes those numbers are typical, plenty of C6's running those times too. M/T ET streets or a comparable drag radial works great, but if you want more of a cross tire then the Nitto Invo's do well too but you will give up a little traction with those.
Received 1,762 Likes
I do 1.3x 60ft
hnaskoct (07-27-2016)
What do you call decent 60ft time for stock gearing and transmission? Jeremy Formato went 1.4's with his M7 Z06. I believe most of guys with C7's are running superb 60 foots.
Received 1,296 Likes
2018 C7 of Year Finalist
I run the Nitto NT05R myself. They are a good mix of street/drag radial. Not quite as much grip as the Mickey Thompson, but better handling. I've heard the Mickeys can feel a bit loose at high speeds.
the 9.95 last year was at 138mph with a 1.54 60'.... It was a 1/8 mile pass with the 1.37 60'. Trans was not shifting correctly and hung on the limiter. It went 6.36@111mph. Should do better this weekend.
cool,will be looking for the update. I'm doing an a and a kit with headers and meth. Wanting to run 10lbs of boost. Its an a8,will be running 18 inch drag radials . What quarter mile et should I expect?
Cam? You will start being limited on high pressure fuel without a 32%+ cam lobe. I would say mid-high 10s @ high 120s maybe with 10lbs and no cam.
