Show us a garage thread
1/4 mile/AutoX
there are quite a few actually !!!! (threads on garages) mine is more towards the bottom of beautiful garages here !!!!
IMXCITD (07-25-2016)
1/4 mile/AutoX
^^^^^ you should see it today, not so spotless.
2017 Corvette of Year Finalist
2016 C5 of the Year
Nothing fancy, just a regular 22x20 garage, added the Rustleum Epoxysheild floor and a few things on the wall. I want to paint the walls soon just don't know what color yet.
My shop.
It's a 36'X63' pole barn. I had the main building (36X48) built in 1994 and have been working on it ever since. I added the lift about 3 years ago, a god sent at 64. No more working on cold concrete. I have a 12'X15' paint booth in one corner and one of the 12' bays has a loft over it for extra storage. It's my home away from home.
IMXCITD (07-27-2016)
Location: Blessed are the cracked. For they are the ones who let in the light.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
My shop.
[ATTACH]ATTACH]
[ATTACH]ATTACH]
OP whatever you do when you think you know how big you want it, add 20% more space. You will also want to make sure you have ample electric sockets, hot & cold water sillcocks, and you can never have enough lighting.
I know for sure when my wife and I go to build our next house (6-8 years) the garage will be roughly 30x40 (Each ride will have 13x30 space roughly). I also plan on building a separate building away from the house.
Current Garage (20x22 - Worthless).
Same here. 20 x 22 two tool boxes and shelves full of supplies. I have one 120V plug to power stuff. I hate my garage. I cannot work inside of it. I work outside in the driveway....... in GA My two car garage is really a tight two car parking spot.
One day, I'll build a separate garage to play in and my attached garage can be a "yuppie" garage. I've given in on the size. it started out 30'W x 28'D and now, if it gets built it will be 36'W x 40'D....... you only get to do something like that once, do it right.
Ahhhh, I hate my garage...........
So we're going to be looking for a new house in the next year or two. I would really like a 3 car garage but those are kind of hard to come by in my area.
If we went with a two car garage how long and tall does it need to be to accommodate a lift so I can fit three vehicles in it?
His and Hers
Size matters. everything else is less important.
When we built our current house about 10 years back, the initial plans showed a decent size 2 car garage. First thing I did on marking up the plans was to increase it to a 3 bay 34' x 26' building with the bigger size garage doors (higher, wider) and a higher ceiling joist height. Being able to get my full size pick up in, and have working space between it and the work bench I knew I was going to build across the width of the building, was essential.
So I have space for vehicles, spare sets of wheels/tires, plus room for power equipment, a big pillar drill, etc., etc. The woodworking stuff was originally in there as well, but it's now in the utility part of the basement.
I have both 120v and 240v circuits in the garage. The electric service entrance is in the garage, which made things easy. Plus, I had the electric company "heavy up" the supply to 400 amp service when they hooked us up. Not much of an on cost when it's a new supply, and with multiple heat pumps, not a bad idea for future expandability.
