need expert advice on manual transmission fluid change
Hello all,
I would like your expert advice and opinions on manual transmission fluid change.
I read the service manual for c5 manual transmissions and said it does not need change until 100k.
I am currently sitting at 46K and not sure if I should get it done. My issue is if I do get it done it will be at the dealer. I don't want to spend that money if it is not needed.
Have you done transmission fluid change and did you notice any change in the way your car runs?
Thanks in advance.
Thanks in advance.
[FONT='Franklin Gothic Medium', sans-serif]Every 100,000 Miles (166,000 Kilometers):
[/FONT]
[FONT='Franklin Gothic Medium', sans-serif]– In heavy city traffic where the outside temperature regularly reaches 90[/FONT][FONT='Franklin Gothic Medium', sans-serif]F (32[/FONT][FONT='Franklin Gothic Medium', sans-serif]C) or higher.
[/FONT]
[FONT='Franklin Gothic Medium', sans-serif]– In hilly or mountainous terrain.
[/FONT]
[FONT='Franklin Gothic Medium', sans-serif]– Uses such as high performance operation.
[/FONT]
[FONT='Franklin Gothic Medium', sans-serif]NOTE: If you haven’t used your vehicle under severe conditions listed previously and, therefore, haven’t changed your automatic transmission fluid, change both the fluid and filter. Manual transmission fluid doesn’t require change.
[FONT='Franklin Gothic Medium', sans-serif]t[FONT='Franklin Gothic Medium', sans-serif]his information can be found here
[FONT='Franklin Gothic Medium', sans-serif]http://www.corvsport.com/Corvette/C5/2004/C5_2004_MaintSchedule.html
[/FONT][/FONT][/FONT][/FONT]
[/FONT]
- [FONT='Franklin Gothic Medium', sans-serif]Replace spark plugs.
[/FONT]
- [FONT='Franklin Gothic Medium', sans-serif]Inspect spark plug wires.
[/FONT]
- [FONT='Franklin Gothic Medium', sans-serif]Change automatic transmission fluid and filter if the vehicle is mainly driven under one or more of these conditions:
[/FONT]
[/FONT]
[/FONT]
[/FONT]
- [FONT='Franklin Gothic Medium', sans-serif]Manual transmission fluid doesn’t require change.
[/FONT]
It would be a good time to change clutch fluid too. I did the ranger method on mine. It was black and nasty. I had a bit of a sticky clutch pedal in heavy stop and go traffic. It needed changed.
I've been reading and watching the Ranger method and ready to do it when I get home today. My clutch fluid is black and nasty too.
Amsoil Torque Drive ...
Anti-Venom Mod...
Revised Ranger Method...
will all provide a little smoother shifting...
want more? C6 Z06 shifter or aftermarket MGW seems to be the shifter of choice...
Check your shifter box and see if the rubber grommets on the shifter box are rotted and cracked...if they are and it's moving it will make shifting harder...
Anti-Venom Mod...
Anti-Venom Mod...
Anti-Venom Mod...
see here:
if that's not what you're referring to, can you give me a link how to check the shifter box?
Sorry I am new to the corvette.
Sorry... yes at 10:56 in the video he is shining his light on one of the three "bushings" that hold the box to the TT... they can be dry rotted and cracked and will let the lower box wiggle around... forum vendors sell replacement bushings to make the box solid...
IF the box and shifter look filthy... I would take it out... clean it, lube it and then reinstall it...
Anti-Venom Mod
https://www.corvetteforum.com/forums...procedure.html
Modified Ranger Method
https://www.corvetteforum.com/forums...er-method.html
Anti-Venom Mod
Anti-Venom Mod
Anti-Venom Mod
what year?
Hello all,
Thanks in advance.
Thanks in advance.
Earlier C5's with M6 --Do Not use synthetic ATF.
Do a search on this.
Dave
Yes, my is an 04. I took it to the dealer to do the trans fluid but they didn't have the fluid in stock so they have to order it. That's not a good sign. That tells me they don't work on these enough for me to trust them with my car but I don't have many options.
Brother there are a TON of dealership goat ropes... NOT a good place to take your vette in MOST cases... 8vette7 said it best "they don't even know how to spell C5"
Anyway it's a very simple DIY... just drain and refill...you can get a pump from Amsoil... I ordered the Torque Drive Fluid and the pump at the same time... I've used the pump for numerous other projects... great little pump...
https://www.amsoil.com/shop/by-produ...tle-hand-pump/
You can do the Anti-Venom Mod while your under there and CAGS delete also if it hasn't been done... this is the CAGS delete I used..
http://www.westcoastcorvette.com/p-4...1997-2013.aspx
Amsoil Torque drive synthetic is much better than the stock fluid, and pretty much the best fluid you can put in your c5 manual transmission. Even then, I would still change it every 50k.
For what it's worth IF you go buy a floor jack and some jack stands and do this yourself... it will probably be cheaper than having the stealership do it... and you'll know it's done properly. Good luck either way
