[Z06] Trunnion upgrade....
Anyone have input on trunnion upgrades?
People told me to go OEM, stay away from Comp cams. And a few people listed some others as decent but not to throw away the money.
What some of you others say?
I have the Comps, no issues but plan to install YT rockers soon - purchased thru Tony Mamo
Seen way too many comps fail. BTR are definitely better. I thought mine were fine too until I popped a valve cover and had several broken. Replaced them with BTR stuff for now. So I have 3 BTR and 13 comps. Once I decide what to do will be replacing all of them.
I just bought the Straub kit. I have the comp kit now. They haven't given me any reason to take them apart but I'm curious to see if there is any wear on the trunnions like others have seen. I'll probably check them next weekend.
OP-Are you running the stock cam and springs? If so, I'd just stick with OEM.
Straub kit is still too new to tell so hide and watch on that one.
Comp Cams kit has many documented fails but in their defense we'll never know how many of those are from bad install.
The BTR kit has superior quality steel on the trunnions vs the CC kit, bigger snap rings too but the problem here is you can't get them anymore as BTR has been out of stock for 4-5 months now.
So that leaves the only tried and true option that's still left. The one I have been using for a year and a half so far with no issues. CHE bushing rockers, I got them from WCCH, took off my noisy CC trunnion set installed these and it's been quiet ever since.
There are other options but at $1500.00 and way up from there. The CHE's are about $450.00 with your trade in of the old rockers, or so. No extra machine work required. You can't beat that price with anything else and get that kind of a quality part.
I had a set of YT's a while back they didn't last 4 months before the roller tips started give way. NO Thanks on those. And if you have an LS7 with any kind of extra lift on the cam you'll need to have the rocker stands machined for them to fit right. UGH.
Good luck you guys.
Good luck you guys.
Harland Sharp
Harland Sharp makes a good upgrade kit. They either have them in stock or you send them yours and they turn it around. Someone on the Forum here did a really good write up on all the choices sometime back.
Good luck you guys.
Good luck you guys.
I swapped my Comp trunnions for the Straub Technologies bushings and I had them for about 4000-4500 miles so far without incident.
After 4200 miles my CC were showing signs of wear.
Check out my link for some pics and more information!
https://www.corvetteforum.com/forums...post1592267727
The Straub looks like the best option to me..... I like that the bushing gets lubrication by other means than just splash, like the CHE set. The CHE's will wear over time. I had them in my engine for a year. They definitely were not as tight after a year as they were when installed. No way in hell would I use or recommend the Comp's. If it quacks like a duck, it's probably a duck.... And there's a hell of a lot of quack'n going on around them Comps.
~2 months ago I would have said I have 18k miles on my comps and they are running fine, until I popped the valve cover and found 3 of them coming apart. Anyone who says there comps are fine needs to pop the covers to double check that.
I'll probably order the straub kit today.
BTR list smith bro bushing kit, interesting.
http://www.briantooleyracing.com/smi...grade-kit.html
http://www.pushrods.net/trunnion.html
I expect the bushing style kits to wear eventually and that's perfectly fine with me as long as the trunnions stay in good shape. I'd be surprised if Straub wouldn't sell you another set of bushings at a reasonable price. If not, you can have any local machine shop cut you some new bushings.
Colorado Speed sells the Straub bushing kits too.
https://www.corvetteforum.com/forums...grade-kit.html
Can you give me a few more details on what failed? Also what was your setup when it failed? Big cam? How much lift? What max RPM were you running? Type of driving - drag, Auto-x, track, street?
FYI, Yella Terra had a problem years ago that was resolved. So the timeframe in which someone had issues is also relevant.
Good luck you guys.
Good luck you guys.
On the pricing side, I assume you probably went with CHE's before Straub came out with their version - Straub's solution is considerably less expensive. Marketplace competition is a good thing.
Btr has the replacement bushings and they are really cheap. $3 each
Ordered the Smith Bros ones from btr. I would never give a dime to cospeed and counldnt find any other vendors I like with the straub kit so I did the Smith Bros from Brian tooley.
