Roller tip rockers for stock ht. valve covers
Old 07-28-2016, 03:06 PM
ehrhartc
ehrhartc's Avatar
Default Roller tip rockers for stock ht. valve covers
Can anyone direct me to a set of roller tip rockers for a Mark IV 454 that will fit under the stock height valve covers? I am running a Crane 242/242 duration 520/520 lift solid cam and want to use the stock covers - these do not have drippers and no power booster depression.
Old 07-28-2016, 03:28 PM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
These are advertised to fit:
https://www.summitracing.com/nv/parts/cca-1411-16
Old 07-28-2016, 05:09 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
compcam roller tips, pretty easy to put roller tip under stock valve covers.
full roller rockers are more difficult to fit under stock height.
I managed to fit Crane Rollers under stock height with just a bit of massaging on a few the rockers.
Old 07-29-2016, 09:48 AM
ehrhartc
ehrhartc's Avatar
thanks for the suggestions.
Old 07-29-2016, 12:32 PM
ddawson
ddawson's Avatar
What about using the stock looking cheater valve covers?
Thats the way I did it.
Old 07-30-2016, 08:36 AM
Tim Ware
Tim Ware's Avatar
There are 1/2" valve cover spacers that might give you the clearance you need.
Old 07-30-2016, 08:49 AM
GOSFAST
GOSFAST's Avatar
Been these type builds for some years now, full-roller platform, retro-hyd lifters/true roller rockers, with 100% stock valve covers and single-thick V/C gaskets.
Many of these builds are on Vette's that get judged at the shows, no problems so far!
Thanks, Gary in N.Y.
P.S. We use mostly Comp's rockers/poly-locks (intakes) with a 1/2 set Crower's poly-locks necessary on exhaust's only.
Old 07-30-2016, 11:15 AM
69Vett
69Vett's Avatar
I like those rollers, (lowprofile) and will use them next build,
why poly locks on exhaust only ?
To Roller tip rockers for stock ht. valve covers
Quick Reply: Roller tip rockers for stock ht. valve covers
