1968 Owners wiper/headlight overrride
Does anyone know the correct setup for the override switches?
Below my dash under the right knee is the roundknob and two override pull switches side by side.
[I]Every photo I've seen, including AIM shows override pull switch, **** and override pull switch order.
Also, on the back side there is this block that the hoses connect to, which is not in the AIM or any parts catalog.
Anyone have a similar setup?
I don't have a 68, so just a guess. The right override switch is closest to the wiper switch and controls the wiper door. The left override switch is closest to the headlight switch and controls the head lights. That's at least how it works on the other cars.
Received 2,878 Likes
Hi R,
The info I have to refer to indicates this was the placement of the vacuum overrides and wiper 'stop' **** on early 68 NON a/c cars to at least serial number 9774.
On all a/c cars, and others after that serial #, the **** moved between the vacuum overrides and the trio moved directly under the steering column.
Alan
Later placement.
Alan
Later placement.
rebuild (07-29-2016)
Hi R,
Alan
Later placement.
Alan
Later placement.
Hi R,
Alan
Alan
Later the bracket was moved under the column, and the wiper motor switch was centered between the 2 vacuum switches. As far as the VIN when the change took place, I'll take Alan's word on that.
The bracket and connector are pretty rare, especially that connector. I've only ever seen one other one, in 40 years of playing with Corvettes.
When 68 production first started, that was the placement of the switches, with the wiper motor **** to the left of the pull downs, and the whole assembly mounted under the tach.
Dementer sole survivor
Received 6,259 Likes
2016 C3 of Year Finalist
Ive got the same one. Oct 68 build. You can try some of the vette slavage guys in the vendor section. Ive had good luck with George.
https://www.corvetteforum.com/forums...un-merged.html
Good hunting!!
Good hunting!!
