Spare tire
Spare tire
Are there any new inexpensive solutions for the space saver spare? I have zero faith in the original one even though it looks ok holds air and all that.
That's a really good question!
I recently took my spare out and checked the pressure.. it was down to about 25 lbs. I washed it real good and put a solution of dawn dish washing soap and water around it and filled it 5psi at a time while flipping it over and watching for leaks. Found no bubbles but still I'm afraid of a 20 year old spare even if it still does look new.
Like Klondike says, don't trust the spare tire further than getting home or the nearest tire store. I see people drive with those replacement tires on the highway and it scares the jehebbers out of me.
Those spares are only intended for low speed (under 40mph) short distance trips to get you to a garage or tire store for repairs or a new tire. It's definitely not to be used as an everyday tire. If it holds air and you can follow the guidelines of its designed use, you will be fine. The spare tire isn't going to explode or fall off the rim as many would think unless it's severely dry rotted, won't hold air, or the rim is rusted beyond safe use.
The spare is also part of the rear-collision impact protection. I would not drive far or fast on a 20 yer old spare.
I removed my spare and carry this instead. As others stated, spare looks fine and holds air fine. Not sure I trust it and I also don't want to deal with two flat tires...
Most new cars don't even have spares anyway, even though they come from the factory with run flats, most owners replace them with better performing regular tires.
1. Lose the added weight
2. Cleans up the rear end
3. Isn't going to help you at all in a crash.
4. Carry a cell phone at all times.
You are wrong on #3. It was designed to be part of the safety design to have the spare tire under the rear end help protect you from a rear end collision. It was a GM proven fact that they do offer a level of protection.
25 -30 year old tire...made to hit rear diff in rear end crunch, Still going to need rear body parts,spare or not...There are a lot of "Drivers" out there that know how to drive from games.....90 has spare , 86 was dry rotted....86 DD when home.....Drive truck...I've seen it all...ziggy
It is not a life saver. It is equivalent to wearing a helmet while sky diving. If your shoot doesn't deploy, the helmet is wearing you at that point. Same thing when 30 year old soccer mom sipping on some star bucks while texting in her 6,000LB. Denali rear ends you.
The reason they offered a spare tire delete bracket was to simulate the spare tire carrier in the event of a crash. Either the device or the spare isn't going to do much for you in the way of preventing a fatality. The spare tire delete bracket is just there so the car doesn't have to be re-certified for crash test ratings without a spare. That is big money.
A plastic rubber container with flimsy aluminum brackets isn't going to transfer crash energy anywhere. Its just going to slide out from underneath the car. Either way the car is pretty much totaled.
There are choices BUT they nearly all are done on the "wrong" bolt circle but could be used with an "adapter". Ideally a couple people should split the "pair" of required adapters. There's way to many to list.
I did the adapter configuration for a ZR-1 owner with the C6 "big brakes" but the fellow I used for the adapter has passed. There's many others I expect. I used a Caddy spare for his.
Really, as others have already said, if the spare looks good and holds air, I don't think you need to fear using it. The spare in my '94 is original, looks fine, has seen no significant heat cycles or UV radiation. I have no plans to try to replace it, and would not hesitate to use it if I need it.
I would, of course, drive gently on it, and only as far as necessary, but I would have no worries at all about bolting it onto the car and slow-rolling along to get me to someplace where a permanent solution can be accomplished. These spares were never intended for more than very short-term, limp-along duty, and I can see no reason to worry that mine isn't still adequate for that task.
Live well,
SJW
Live well,
SJW
Proven fact?
Mine will hold air, but has a bunch of cracks in the tread area. I fill it up with air, and it holds air. But like with any tire, you have to check it every so often to refill it back up. Thought of trying to get a flexible valve extension that I could pop out to check/air it up without having to drop the carrier and pull the tire to do that.
Had to use it once several years ago on the interstate and it worked fine. I did a couple of years ago put fix a flat in it and rolled it around then aired it up figuring that might seal any small leaks that could be in there if there are any. But then later I read that sealant only works temporarily. But the tire holds air like a normal tire so I just leave it.
There was a thread about getting a new spare:
https://www.corvetteforum.com/forums...-more-yrs.html
When I called Tire Rack the very unfriendly and unhelpful person told me no such thing for a C4. YMMV
spare
Keep the spare but carry a small inflator (harbor freight) and a tire plug kit. The slime is ok but it messes up the tire pressure sending unit and the tire guys hate it.
You sure about that? I have read several articles that claim it doesn't fix everything 100% but it does something to help. Better would be a brace but there it is. Besides, I have had some tire wrecks that no amount of slime would help and the only fix is a tire.
I recently dumped my tire and put in a fresh tire from Tire Rack. A few years ago anyways. And yes, I did have the situation where only a wheel and tire would work.
Live well,
SJW
Live well,
SJW
