C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Valve Cover Emblems Fell Off
Old 07-30-2016, 03:41 PM
KJL
KJL's Avatar
Default Valve Cover Emblems Fell Off
I actually pulled them off as they were about to fall off. The black adhesive backing is still on the valve cover. Is there anything that can be used to re-adhere the emblem to the cover? It would need to be high temp. I was thinking about using high temp silicone and just sticking them back onto the black backing after I clean it up. That stuff is stuck on there very well.
Thanks.
Old 07-30-2016, 04:34 PM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Get some emblem adhesive at your local auto parts store. Just takes a very small amount.
Old 07-30-2016, 04:59 PM
Goldcylon
Goldcylon's Avatar
Clean the area on your cam cover and the cam cover emblem then apply some Permatex hi temp RTV. GC
Old 07-30-2016, 08:39 PM
kenpeindl
kenpeindl's Avatar
I used J-B weld hasn't come off in over a year.
Old 07-30-2016, 09:28 PM
Z51JEFF
Z51JEFF's Avatar
I used black RTV sealent. Don't put it over the black stuff left on the cam cover.
Old 08-04-2016, 01:09 PM
KJL
KJL's Avatar
I used high temp RTV and stuck on top of the original black foam adhesive that I cleaned with brake cleaner. So far so good!
To Valve Cover Emblems Fell Off
Quick Reply: Valve Cover Emblems Fell Off
