New High Flow LT1 DI Fuel Injectors
Old 08-05-2016, 09:07 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default New High Flow LT1 DI Fuel Injectors
-25% greater flow than stock
-Fits Gen 5 LT1 engines
-Set of 8
-Brand new - no core required
-Used in the Katech Street Attack LT1 427
http://store.katechengines.com/high-...tors-p544.aspx
__________________
Contact:
(e) zach@katechengines.com
Old 08-05-2016, 10:14 AM
jacksnorm
jacksnorm's Avatar
Wow finally... I will be ordering some shortly..
Old 08-05-2016, 10:26 AM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,228 Likes on 775 Posts
These flow more than lt4 injectors? The part number says DW in it, are these DeatschWerks?
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 08-05-2016, 10:36 AM
Katech_Zach
They are made for us by DeatschWerks. Flow rate is near LT4 injectors, but during development of our Street Attack 427 LT1 we found these injectors made more power than the LT4 injectors so we stuck with them in the crate engine.
Old 08-05-2016, 08:35 PM
Higgs Boson
Higgs Boson's Avatar
Received 2,379 Likes on 1,238 Posts
They say GM on the outside, are they reworked stock injectors?
Old 08-05-2016, 09:32 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
you saw that also. But really should work good for a more higher power motor. That is if they have been matched to flow really close to the same.. 1,k for a set of really good inj is not bad at all. Crap I paid 1600.00 for a set that would work in the c5.. Robert
Old 08-05-2016, 09:54 PM
Higgs Boson
just not sure what these will do over a set of LT4 injectors, especially when we have known good data for the LT4 injectors.
Old 08-06-2016, 09:27 AM
Katech_Zach
Correct
See post #4
Yes, they are very reasonable. Thank you.
Old 08-06-2016, 10:46 AM
Higgs Boson
post 4 doesn't answer the question.....
Old 08-06-2016, 02:16 PM
Katech_Zach
You asked...
We tested..
Old 08-06-2016, 02:18 PM
Higgs Boson
Let me rephrase the question:
HOW do reworked stock injectors "make more power" than LT4 injectors that flow (approximately) the same amount?
Old 08-06-2016, 02:55 PM
Katech_Zach
There was something about the re-worked injectors that changed the combustion in such a way that made more power. We can make an educated guess that it has to do with spray pattern, atomization and a more homogeneous mixture. There is no way of proving how, just if there is a difference A-B. It's even more important on a DI engine than PFI and we're seeing how slight changes can make a large difference. GM spent a lot of R&D on the dome profile of the pistons for this very reason.
marcouvo (08-06-2016)
Old 08-06-2016, 05:02 PM
Higgs Boson
What was the difference in power when only the injectors are the variables?
I'll give DW a call to see what they did to them to gain a clearer understanding of why they make more power so I don't clutter up the thread, thanks Jason.
Old 08-06-2016, 05:15 PM
555ctsv
555ctsv's Avatar
So can you whip up a batch of LT4 injectors that go through the same modification process so we can get some serious flow?
Old 08-06-2016, 05:18 PM
joemosfet
joemosfet's Avatar
Let us know what you find, I'm interested to see the difference.
Further, I'd like to see these injectors in a LT4 and see if there is a power difference.
Old 08-08-2016, 09:03 AM
Katech_Zach
LT1 modified injectors in red
LT4 injectors in black
robert miller (08-08-2016)
Old 08-08-2016, 09:18 AM
Katech_Zach
That will probably be the next step if we need more injector in an LT4.
555ctsv (08-08-2016)
To New High Flow LT1 DI Fuel Injectors
Old 08-21-2016, 09:44 PM
555ctsv
555ctsv's Avatar
Did you get a chance to talk to DW?
Has anyone bought these yet?
Old 08-21-2016, 10:20 PM
Higgs Boson
No honestly I forgot. :-(
Old 08-25-2016, 05:34 PM
VAVetteC7
VAVetteC7's Avatar
I'm loven that grill, please tell me I can purchase one
SpeedyD (08-25-2016)
Quick Reply: New High Flow LT1 DI Fuel Injectors
