[Z06] Tony Mamo heads, cam, ported msd install
As some of you have already read in another thread I just got the results of my Tony "Mamofied" H/C/I install. The numbers were a shocking 642/552 SAE on a dynojet that does not give numbers away. Dyno was done on stock rims and tires. C6Z's that have put down 605-610rwhp on this dyno have trapped 140mph in the 1/4 mile. This should give you an idea how good these numbers are. I was beyond happy with the numbers. I am still shocked. I think the previous highest H/C/I C6Z dyno'd 620 on this dyno. People who use this well known tuner (Matt at GP Tuning) and dyno in the bay area(Hayward) California know just how impressive these numbers are. This was tuned for E65. 1/4 tank 91 and 3/4 tank E85 out of the local pump.
My build...
-Mantic twin disk clutch
-2" ARH and Corsa catback
-Tony Mamo heads(trick flow castings)(12.25:1 CR)
-Tony Mamo spec'd cam(247/261 114 PM Tony for exact specs)
-Tony Mamo ported MSD intake
-Tony Mamo spec'd Yellow Terra rockers specifically for his heads
-Nick Williams 102 TB
-ATI super damper 10% pulley
-Halltech MF103
-flex fuel kit supplied by Matt GP Tuning
-injectors supplied by Matt GP Tuning
-Walbro E85 fuel pump
-Stock LS7 block
I want to thank everyone who helped me with this build. Matt at GP Tuning for a great tune and all of his help. He is one of the best tuners I have ever used(and I have used a lot). Also, Josh and Adam at JRG Motorsports for doing my install. I have used Josh for the last 10 years and he is the best in the area. This is my 3rd or 4th Z he has worked on for me. I have never had an issue with any of his work,top notch. I CAN NOT say the same for other shops in the area.
A special thanks to Tony who spec'd my build. I called Tony to order a ported and shaved MSD. While ordering the MSD he tried to convince me to try his new heads and use a cam he spec'd to go along with the Mamofied MSD. I was hesitant at first because I have had great success with stage 2 WCCH. I am sooooo glad he convinced me to give his heads and cam a shot. These numbers destroy my previous 3 H/C/I installs I had done in the past and all of my cars had big cams. Not only were the results amazing but his customer service is the best of the best. He went above and beyond what any vender has ever done to help me in the past. He took my phone calls and responded to all my emails(and there were a lot!) He talked with Josh multiple times to help with getting this install absolutely perfect. This was Josh's first time installing one of Tony's combos I believe.
Bottom line is give Tony a call if you want a the best of the best. His work is top notch. If any of you are considering his heads and intake, consider no longer. You will be more than happy as I am.
I can't wait to see what she will do against some local cars I know and i will hopefully be going to Shift Sector this fall. Here is a link to a vid of what it sounds like at idle.
My build...
-Halltech MF103
-Stock LS7 block
Very impressive !!!! I talked to Tony when I got my ported MSD last year about using his heads sometime in the future, so it's great to see Tony's setup putting down big numbers. Hope to hear you back up the dyno numbers with solid ET and MPH at your future events !!!
congrats !!!
congrats !!!
Awesome results. I've talked to tony about a set of these heads as well. If I decide to stay n/a this is the route I will go. Any idea how much difference the e65 makes vs straight 93?
Probably not much at all. You will have to go with a 12.0:1 compression instead of 12.25:1 which i did. I would imagine only a few hp tops
HC Mechanic (12-28-2017)
And you can see the Trickflow logo in the pics.
Common Dan, you're smarter than that. Power level does not mandate higher spring rates. And Tony has been saying he's working with YT to come up with a different design. I'll wait to hear from Tony on that.
From the pics they look like the standard YT UL for LS7's.. And imagining the spring rate and cam profiles involved (what it takes to make that kind of power), I don't predict they will have a long life in that setup.
On "the different YT design", I am all
If these YT's have beefed-up p-rod cup and trunnion areas, that would be excellent, and a winning combination.
Stock LS7 block? I apologize if you mentioned it already.
I am curious to have Tony's input on using his stuff in a roadrace application. I personally just want the car to run on readily available 93 as I don't want to carry 150 gallons of fuel to the track every event.
Car makes fabulous power. Plenty of torque (400 +) early which makes me very interested. Enjoy it!
Spring rate is driven by peak rpm, lobe profile and valve side mass.
Enough on that.....
I want to know more about the heads. What are valves used, what seats are being used, which CNC profile was used (full on race, street, etc), and most importantly - off idle characteristics.
Seeing the cam duration has a 15 deg split, and that Tony spec'd the cam, I am a bit surprised to see that much of a split after following his comments regarding the level of effort he puts into the exhaust port. Frankly, I was hoping for a cylinder head that I could run a much tighter LCA.
HC Mechanic (12-16-2017)
I've got 355 CID small blocks making over 600hp with stock spring rates.
Enough on that.....
Enough on that.....
Racingswh (08-12-2016)
The car has a stock LS7 short block with a cam, johnson lifters, Mamo ported TFS 260 castings, YTRockers, ported MSD manifold, 2" headers, flex fuel kit, E85 rated Walbro 450 pump and 57lb at 4 bar injectors. Compression in the low 12s and tuning of course.
Mantic 9000 twin gets the power to the ground.
Wow! Mamo is a bad ****.
As I stated in another thread discussing this package, I'm absolutely thrilled with the results. It exceeded my expectations or certainly met the most I could have legitimately hoped for and it was a pleasure working with and dealing with Dan (the owner) thru the course of this project (which took months). The power curve is wide and flat and it just makes big power and big torque at any RPM worth discussing (over 3500). I don't have alot of time right now but I wanted to quickly address Dan_the_C5_man's questions to make it clear for everyone
I have already stated in many of my previous posts (in various different threads) that I am using TFS castings for my new LS7 program (so no surprise it has TFS on the end pad although they are working on including my logo in future castings). Note I could have used Brodix (and almost did) but the TFS were more cost effective for me and more importantly for you guys as well (I could sell them for less money net) and the castings are excellent quality.
The rockers I had Yella Terra make and while they may look a little similar to a stock LS7 Ultralite they are not the same at all. I waited 6 months for the completion of these rockers and they are dedicated to my new LS7 head.....hell the box says Mamo heads right next to the part number.....LOL (the pile on the right side of the shelf is the LS7 HR rocker for my heads....PN 6754
I want to chime back in here and hit a few other things but I'm buried in emails now.....will revisit this thread soon!
Cheers,
Tony
PS.....Here is pic of my new SR rocker arm I had specifically built for these heads and the HR version (non adjustable) that Dan is running to the left
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
The following 2 users liked this post by Whis9:
HC Mechanic (12-16-2017),
The Highlander (10-15-2016)
