C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] What do you guys do for winter tires?
Old 08-19-2016, 04:58 PM
Fast Cars & Horses
Fast Cars & Horses's Avatar
Default What do you guys do for winter tires?
OK, I have Bridgestone Potenza Pole Position RFT on a 2006 Z06 now. They are extreme summer tires. I just went looking for a set of all season tires to swap out in a few months and they don't make ANY in the stock C6 Z06 sizes.
I have after market rims on my current tires and was going to use my stock rims for winter tires. I'm in Oklahoma and I never drive in ice or snow anyway, but I will be driving in the cold.
I have a C5 with Rival S for summer and Michelin Pilot Sport AS for winter....I can always drive the C5 and put the C6 up for the winter, but I really don't want to do that. What's the answer? Will I be ok in the cold with these tires? What is worst case scenario? Should I just realize I can only drive it on days where the temperature is above 40 degrees? It's kept inside where it doesn't freeze. Thanks for any response.
Old 08-20-2016, 10:12 AM
racerx3317
racerx3317's Avatar
I don't drive the car much, if at all, in the winter much less snow. I'm on MPSSs now and they are fine unless it's below freezing. Then the tires are like rocks. I think Pirelli makes something in 19/20s that would work but you'd need different wheels.
Old 08-21-2016, 12:58 AM
LMB-Z
LMB-Z's Avatar
I think you can drive in winter with summer tires, you just probably wont get great traction. Just be easy on the go pedal. I have no idea if my tires are summer, winter, fall, or what. I just know they are rubber. Its not a big deal to me. Just my .02
Old 08-21-2016, 10:31 AM
Fast Cars & Horses
Thank you everyone. I think I better only drive it above freezing. My tire guy from Discount Tire (has done Vettes for years) was at the car show yesterday and said the same thing. It'll be an experiment this winter, so I'll see how it feels in different temperatures. Thanks!!!
Old 08-21-2016, 12:01 PM
Brandon619
Support Corvetteforum!
Brandon619's Avatar
I drive on my Continental Extreme DW tires year round but we do not get winters here just cold and wet stuff from the sky.
Old 08-22-2016, 10:58 AM
MyLS1Hauls
MyLS1Hauls's Avatar
Summer only compounds (ones not rated M/S) lose significant dry traction when temps get below 50*. There are a few tire models out there that specifically say not to even move the car when the temps get below 40*, as the tires can and WILL crack. The newer Goodyear SC2 tires are a prime example...I believe the Michelin PS Cups also say this. I've seen brand new Camaros 1LE/ZL1s on the dealer lots in the winter, with cracked Goodyears. Can't speak to the Bridgestones, as I've never used them.
Once daytime temps start to regularly fall below 50*, my car gets put up for the winter. My PS2s get dicey at WOT in these temps, and to me, it just isn't worth risking wadding the car up.
Old 08-22-2016, 02:02 PM
LEJ ZO6
LEJ ZO6's Avatar
Default Winter Tires
My car is a daily driver. I drive it all year round on Michelin Pilot Super Sports. No problem at all.
Oh, yea, I live in Florida.
*El Ocho* (08-25-2016)
Old 08-22-2016, 02:24 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Arizona, so just driven it and enjoy the sunshine.
Old 08-22-2016, 06:23 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
It's not only traction in accelerating that's a problem but also traction when stopping.
I'm running the Bridgestone RE050A run flats on my Z06 and I was in northern NM when the ambient was 33 degrees. I was going down a pretty good grade and there was a tight corner at the bottom. I gently applied the brakes and my brakes locked up as all four tires were sliding. The pavement was dry and the sun was out. I managed to slow down to where I was able to get around the turn by gently downshifting and using the engine to slow me down. Brakes were worthless as all they did was lock up because the extreme summer tires were not worth a **** on a cold morning. Later in the day, the temp was up in the 50's and I had great brakes.
Old 08-22-2016, 09:07 PM
Fast Cars & Horses
Thank you for this story, I think I'll error on the side of caution and only take it out after it warms up.
Old 08-23-2016, 03:44 PM
dmuellenberg
dmuellenberg's Avatar
Is your ABS not working? ABS should prevent your brakes from locking up like that.
Old 08-23-2016, 04:58 PM
Unreal
Unreal's Avatar
Either way, if ABS is releasing the brakes, you aren't stopping.
Old 08-23-2016, 06:45 PM
LMB-Z
LMB-Z's Avatar
To the OP, your climate is not much different than mine here in east Texas. I don't think you will have any problems with any tires, whether they are summer, winter, fall, or spring tires, unless there is ice/snow on the roads. Just take caution during those times or stay at home.
Fast Cars & Horses (08-23-2016)
Old 08-24-2016, 09:15 PM
racerx3317
racerx3317's Avatar
https://www.corvetteforum.com/forums...ter-tires.html These were the tires I was thinking about. If you absolutely have to daily the car and you live in Minnesota or something then this is probably the way to go.
Old 08-25-2016, 03:28 AM
Oleman
Oleman's Avatar
I run the Bridgestones all year with no problem have done it since I bought the car new.
Old 08-25-2016, 12:42 PM
*El Ocho*
*El Ocho*'s Avatar
yeah, living in South Florida I have no Idea what a "real" winter is......
Old 08-25-2016, 09:04 PM
JoesC5
JoesC5's Avatar
I never felt the ABS. Only thing I can figure is with all four tires not rotating, the ABS did not know the car was actually moving, thus did not apply the ABS.
To What do you guys do for winter tires?
Old 08-27-2016, 11:15 PM
dmuellenberg
I guess I would have the ABS checked out as it shouldn't do that. ABS should know that the car is moving when you hit the brakes and should prevent the tires from locking up like that - as that is what ABS is for.
Old 08-27-2016, 11:21 PM
dmuellenberg
ABS doesn't release the brakes, it just prevents them from locking up by inducing a pumping action which is proven to stop the car quicker than by locking up the brakes. My point is that if the brakes are locking up then ABS must not be working and should be checked out. The ability to steer is also greatly reduced when the brakes are locked up.
Old 08-27-2016, 11:29 PM
C5 Hardtop
C5 Hardtop's Avatar
What is winter like in Shawnee, Oklahoma? Wikpedia normally has climate data on cities, but not that one.
Quick Reply: [Z06] What do you guys do for winter tires?
