1982 Corvette Fuel Tank Recommendation.
Old 08-21-2016, 05:02 AM
usmilret
usmilret's Avatar
Default 1982 Corvette Fuel Tank Recommendation.
I removed my fuel tank and need another one for a 1982 Corvette. Can anyone recommend a good vendor? I am looking for a decent tank with a zinc coating or something comparable. Liner or no liner.
Old 08-21-2016, 09:33 PM
terry82
terry82's Avatar
I would call willcox and tell them to ship me one.
Old 08-21-2016, 10:37 PM
billschroeder5842
Zen Vet Master Level VII
Support Corvetteforum!
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
X2
No mistakes there. While you have everything apart, consider replacing your fuel pump with a 85-89 Vette model. It is a direct bolt in and it increases your fuel pressure-- lots.
Old 08-21-2016, 10:44 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
, or Zip... they have it for $230 and you could ask them for the Carlisle discount (free shipping if you stop by their tent at Carlisle)...
photo courtesy Zip Products
http://www.zip-corvette.com/68-82-c3...-gas-tank.html
Good luck... GUSTO
Old 08-22-2016, 02:48 PM
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
We have them, I don't know I would use the 85-89 pump though, those are designed to flow a much higher pressure and without other modification that would not be a good thing.
Old 08-22-2016, 04:12 PM
terry82
terry82's Avatar
That has been a regular fix for the crossfire for 15 years that I know of.
Old 08-22-2016, 04:14 PM
billschroeder5842
Yeah, no issues, fuss or muss.
It really makes a difference
Old 08-22-2016, 05:10 PM
slickfx3
slickfx3's Avatar
agree did mine and the engine don't run lean on demand anymore
Old 08-22-2016, 10:05 PM
Buccaneer
Buccaneer's Avatar
Location: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Received 1,005 Likes on 688 Posts
There are no issues installing the 85-87 corvette pump. You still have to adjust the regulator on the rear TB though for 13psi. If you do replace the pump, I would highly suggest you replace the bladders in both TBs if you have never done that.
One last note on the TB rebuild kits, get the Sorenson kits from Autozone, they are good kits and have the "correct" bladders, trust me on this. P/N: 96-629 I think they are around $45 still. There are other kits available for CFI TBs. However, they are not all the same quality and they all do NOT work properly in a CF.
Old 08-27-2016, 06:46 AM
usmilret
usmilret's Avatar
I have a fuel tank coming in.
Old 08-29-2016, 02:24 AM
Buccaneer
Buccaneer's Avatar
Nice! Just a suggestion, but before you install the new tank make sure you install new anti-rattle strips on the tank bands. You can buy them at a few corvette places, but you can use roofing felt cut to the correct measurements at a cheaper price. The ones you buy are going to be the same thing and cost more. Just a tip on that.
Old 08-29-2016, 04:08 AM
usmilret
usmilret's Avatar
That's a good tip to remember and thanks.
To 1982 Corvette Fuel Tank Recommendation.
Quick Reply: 1982 Corvette Fuel Tank Recommendation.
