question on the Renegrade intake manifold
Have a 84 Vette with the crossfire intake, if I switch the intake to the Renegrade intake manifold, is that performance or hp I will feel, or is it not worth the money to do, the intake is around $500 at Summit
A few years back there was a lot of buzz about the Renegade Manifold.
I do believe that there is some horsepower to gain installing one. $500.00 is a lot of money.
I got some advise here on the forum about porting the stock manifold. I invested in a metal removing bit and a sander. I ported the stock manifold and then ported it some more.
I remove a lot of material and I think the results were well worth the time and expenditure I made.
Would I buy one for my 1984. I would not. I would try and port the stock manifold as the investment was minimal and the results spoke for themselves.
here are a couple of links to look at:
https://www.corvetteforum.com/forums...-critique.html
http://www.technovelocity.com/chevyh...rt_polish.html
I picked up a used manifold for $60.00 and used it and no downtime till my manifold was ready to install.
Good luck with your decision.
I'm going to have my stock manifold ported this winter. I'm going to pay for a machine shop to do it. Roughly $125-$200.
I've read you can gain up to 30 hp by putting in the renegade or getting a good port done to a stock manifold.
I can remember and have his claim somewhere that when the XRam came out, they were claiming 100HP with their manifold which I think is a false statement, but I saw a 22HP gain over the XRam with our manifold to the rear wheels. So what does the say about the Renegade...122HP? LOL, I don't think so.
Received 3,043 Likes
St. Jude Donor '05
30 to the ground for $500 is cheap!!
It is actually considering on how much we spent to develop the manifold. I know many other car/racing guys that spend much more for much less. Jus sayin'. It is a very good addition when you have a bigger cube motor for sure.
Here's a picture of what they'll be tackling.
In my photo, I was trying to show there is both an X-plane angle as well as a Y-plane angle when you're porting with an end mill. (More hand contouring is needed after the preliminary mill work is done.)
That sawn section of manifold is interesting! Those casting walls are pretty thin!
Here's where I'd lay some beads. You could make the ramp more gradual. It might be beneficial to get rid of that coolant passage & thicken that area too. Then you could really open up that port.
Pro Mechanic
Improving the "angle" would be better addressed by raising the roof, rather than lowering the floor.
First, it's a straighter shot if you raise the roof.
Second, I tried chopping the coolant passage and sealing it off (strictly in an effort to lower the runners' temps) and it was a **** show. Thing leaked like crazy and it took me a while to get it decently sealed up. Trying to weld the runner bottoms and that passage and have no leaks would really test ones patience. The runners would he leaking to oil/atmosphere. A leak in a runner roof is leaking to plenum which is about the same pressure as in the runner...not a meaningful leak.
Pro Mechanic
Another weird thing about this picture;
What's with the 90* illustration? The manifold flange on a SBC is not perpendicular to the port. The port floor and ceiling should have an angle to the flange of something like 105* and 75*, respectively.
Ex-x, I think we hijacked this thread. The OP's question was about the Renegade.
But I can't help thinking there's something wrong with your section photo showing the 80* and 90* lines. My photo shows a MUCH deeper cut from my end mill, and I didn't break thru. I think my cut was more like 100*, but I didn't measure it. The limit of my cut was matched to the head port. Is it possible your sketch is from the gasket, rather than a match to the head port? That would be wrong.
Pro Mechanic
Hey Tom, I bet that process was a PITA kind of thing, but a worthy one non the less to make improvements. We knew going into the project that heat was an issue and that the water jacket is fairly close and if someone gets too aggressive with a die grinder they will go through or on top. When we developed the manifold knowing this, we eliminated the lower jacket and now has a standard water flow crossover on the end and to reduce the manifold heat issue on the bottom as much as possible. We also knew that people would more than likely at some point with the larger cube motors want to port the manifold so we left plenty of runner material there just for that purpose if they felt so inclined.
Boy looking at the images i'm glad i just forked out the money for the intake.
That said my renegade intake needed a bit of love over the egr crossover.
I had a little wall at the bottom of the intake runner on egr side.
And on that side the intake runner was a little smaller in that area as well.
I also did a little port matching to the edlebrock heads i used, in the end it turned out great with a little extra work involved.
For my setup it was one part of an entire package, i now have power all the way past 5500rpm where before it would fall flat on it's face well before.
Intake alone i imagine will help out with the power in the upper rpm range, those runners in the stock manifold are tiny!
St. Jude Donor '05
the fact it could be further ported makes it a no brainer imo
that intake was the rage back then, lots of mag articles on the "crossram" coming back. Beats a stripe pkg which was about it back then. Those were some dismal days of performance or lack of
