It was running a little hot
It was running at 220 even on a cooler day, but if I pushed it at all it would hit 230 and above. I couldn't run the a/c at all it would shoot up really quick.
I'm putting in a big blower cam myself and so I pulled the radiator and found this....a closer look Totally mattedThe car has an ECS 1500 the intercooler sits in front of the cleaner side of the radiator. The intercooler had no debris at all. What a mess, should run a tad cooler now.
That's interesting. Do you think the placement of the intercooler had any adverse effect on the air draw to the radiator? Maybe causing more debris to end up onto the rad coils?
Asking BC I just purchased an A&A SC, waiting for delivery. Their intercooler mounts in a similar way to ECS' intercooler. I know my rad is clean now, just cleaned it, but I'll be keeping an eye on it after the A&A install.
Received 2,887 Likes
Mine looked like that after the first 3 years. Now I flush it out at least once a year in the spring.
After I posted I remembered the intercooler doesn't sit directly in front of the radiator, the a/c condenser does. The a/c condenser had some debris, but nothing like the radiator. The debris is being sucked up between the condenser and the radiator. I'm thinking I should build a screen of some kind, obviously taking out the radiator to clean it out right is a bigger deal than I want to get into every couple of years. I've seen people's hoses that they've made and so on but if the debris didn't get up in there to begin with that would be better. I'll put some thought into a screen and do some research. If anybody knows of a screen that's all ready out there please chime in.
I'm in Los Angeles. It's got about 53,000 miles. Looking down between the radiator and the condenser I could see some debris was in the radiator but I had no idea that so much of it was completely plugged up. I'm surprised the cooling system worked as well as it did. I was about to spend $900 on a Dewits. This stuff that's in there seems to all be organic mostly fine plant matter dirt and sand. I drive up canyons and on country roads (way too fast). There's plenty of them just outside of town so it's not just city driving.
Not So Fast (08-26-2016)
If I had been on the C6 design team I think I'd have fit a removable screen in front of the radiator much like the lint trap for a dryer. I could pull it out and clean it whenever necessary.
I have a hood vent, removed the back weatherstripping from the hood, I installed a 160 thermostat. I'll do the water wetter and see how it runs. If it's running hot I'll do the Dewitts
