HEADS UP DISPLAY for any vehicle with OBD2
Premium Supporting Vendor
Location: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
We used to sell a GPS powered HUD that was very popular but not very functional and lagged quite a bit. The manufacturer went out of business so we stopped carrying them. Well I came across this unit about a year ago and have been using it in all my vehicles and LOVE IT! This iPhone-thin HUD unit plugs into your OBD2 on any 1996 or newer vehicle. It gives you a multi-color, beautiful, large HUD with speed, volts, water temp, RPM, engine code scanner / clearer, auto on/off with ignition, self dimming with ambient light, time, distance on trip, and alerts to out of range on speed/temp/volts/check engine code.
I have these in stock and make a perfect HUD for a Corvette that doesn't have HUD or is broken (I've had a couple with broken projectors or mounts that vibrated). Great gift for friends and family. Perfect for daily driver vehicles to help be aware of your speed and other important engine parameters at all times.
Check it out here for more info and pics/videos. I will be posting more soon. Installing one on a non-HUD C6 after the weekend. It should literally take a couple minutes to put the unit on the dash, install the reusable reflector, run the wire down the side of the dash and plug it in under the dash!
http://exoticvette.simdif.com/multi-color-hud-unit.html
Email us or call for info / questions. These are selling very quickly. I ordered 100 and I'm down to just about 60 already.
Ship out quick so you'll have it in a couple days!
You have my order.
which years work?
Your post says it works with any vehicle 1996 or newer, but your website says 2007??? You do note that you have it on 2005's.
I am thinking about using on 2003 Chevy Avalanche.
The product arrived quickly and was easy to understand. I originally bought this for my truck (05 Escalade ext/same as an Avalanche) and it didn't seem to work properly. I tried it in a 2014 prius as well and it powered right up, however due to the hybrid design, power is switched on and off to the obdi2 port so unfortunately for it would not work continous use. The product overall had a bright design at night and was very crisp on the windshield, I wish I could have kept it but I had to return it due to compatibility issues.
