ARE Dry Sump - What Oil Filter should I use?
I am in the final throes of my dry sump install. What oil filter are the dty sump guys using for the remote filter kit? I have an ARE system. I sent Gary an email, but I have not heard back from him. Thank you!
If you have the remote filter mounted where the OEM transverse spring was you need a short filter for ground clearance.
Wix is below the oil pan.
I use Mobil 1- 111
Height of filters
M1-111 3.31
M1-203 4.5
M1-302 5.75
I use Mobil 1- 111
Height of filters
M1-111 3.31
M1-203 4.5
M1-302 5.75
Are you running your fender liners up front? If not have you had any problems with that? I was worried about the oil lines and tank being exposed to rocks and what not coming off the wheel.
GM/Delco PF 454, its short enough for clearance. Worked great with the full ARE and Katech pump I had. Its a heavy duty truck filter that held up to high pressures and had a good flow rate too. Was mounted up in leaf pocket. PM me your email for pics if needed.
Anthony @ LGMotorsports (08-31-2016)
Premium Supporting Vendor
PF1210
The PF454 is the shorter version of that.
