Any other way to help stock seat flop?
Recorded an interior video from my last autox and even with my new harness, the seat (and myself) still flopped around. Anything else I can do to help keep things planted? The car is a 2003 with only 17k miles but the seats back has a good amount of play.
Cinch the shoulder straps much tighter. A lot tighter.
When I was in my C5's with a 5 point setup, I had to unlatch the harness before I could reach the door handle because I couldn't move.
I pulled super hard, but i can try harder lol. I think an issue is that they are being restricted by the shoulders of the seat since they go around and not through. I think I need to play with my seat configuration more to get it right.
Using an analogy, think like you are tying off a load on a flat bed truck.
Take one shoulder strap into both hands to get a superb grip. Maybe one hand on top of the other? However you can get the best hold. Then pull the strap straight down your chest using all the force you can.
Nothing was there to hold the back part. I think there will be less movement of the seat-back once you are cinched it down. If moving the seat adjuster forward helps tighten the straps, go for it. I tried that but the two-hand technique worked for me.
Initially, I had some help with seat adjustment, belting and driving position from those in the know at the track. You may want to ask someone in the know to help you while in the pits.
I have a harness bar and 4 point setup for autocross and to be honest if your autocrossing, I am not sure you have to be cinched down that tight on the shoulders. Over the last couple of years I have found as long as my lap belt is good and tight and holds my butt tight in the seat, that is plenty good enough. I still use the should harness, but leave myself a little room to move. Personal preference I guess.
Received 8,958 Likes
Put the seat in the rear position cinch your belts and then move the seat forward to get everything really tight. If you can expand your chest fully to breathe by the time you have finished a 90 to 130 second autocross then you haven't gotten the belts tight enough. The shoulder belts should be tight enough to restrict your breathing if you are breathing hard. That means tight, very tight. Getting your back depressed into the seat will help keep your upper body from moving sideways and take some of the load off your arms and knees. You won't need to use them as much to keep your body in place.
Bill
Bill
