alt or voltage regulator ?
driving home the other night and lights were going brite and then dimming, look down at the gauge and its spiking all the way over to positive and then back to zero , does this for awhile then stops and starts all over again . If it is the regulator can i delete it and get an alt with built in regulator ? How can i tell if my alt has a built in regulator ? thanks
Look for the regulator on the inner fender. I had a problem with mine not charging on my 60. The alternator was a Frankenstein and made up of different parts. Now I know I should have a generator instead but with a nom car I just went and bought a 1 wire alternator and things have been good for the past year.
Were the lights dimming or going completely out ?
There is a thermal relay in the headlight switch that will cause the lights to strobe if an overcurrent condition is detected. Its a safety feature to forestall electrical fires but still give some light so you can navigate off the road.
just dimming looked like they were rapidly going from dim to bright in conjunction with the gauge spiking and going back to zero. its a 65 corvette convertible i replaced the wiring harness and regulator after the motor was rebuilt this winter. Got the parts from lectric limited i believe from ecklers was working fine up until about a month ago didnt realy notice the problem until i was night driving and saw the lights acting up .
You have what appears to be an original style, externally regulated alternator.
It's clear to see that you have a lack of dirt on your engine for the charging system to work properly. Beautiful enging box... good luck with your problem!
Mike
Mike
number3 (08-31-2016)
Not usually an issue and, fairly common with a mechanical regulator but, I'd check the voltage output to the battery anyway just to be on the safe side.
You mentioned having replaced the regulator. The "new" ones are absolute junk!!! I went through 3 before going with the solid state unit.
IMO, the VR-715 is a HUGE improvement over the mechanical unit (steady feed with no pulsation) and, you can even change covers to make it look stock.
Gary
Definitely the regulator is causing the lights to "pulsate". Had the same thing until I switched to a VR-715 solid state unit.
Gary
Gary
Autozone stocks them under their Duralast brand VR715. Most all auto part stores carry a facsimile.
http://www.autozone.com/batteries-st...or/130005_0_0/
ok guys thanks for all your help !
The Wells VR-715 is available almost anywhere, about $28 and you can put your original V/R cap on it so it doesn't look so out of place...
Before you start throwing money at this....
Most auto parts stores can run your alternator and regulator and check them for function.
If one is bad, they can easily figure it out.
I'd try to find an "old time" parts store or maybe even an auto electric store. Bring both items in with you. (alternator and regulator)
I still wouldn't discount Frank's theory about the thermal breaker in the HL switch either.
Chuck
Chuck
Chuck
Chuck
Most Autozones and the like can load test your alternator (and battery for that matter). Not much downside to picking up a Wells VR-715 though. Something you can throw in your glove box and it might just get you home one night if the old mechanical V/R gets wonky on ya...
Chuck
Chuck
With all due respect, my guess is that you haven't purchased a new mechanical aftermarket regulator from your local FLAPS for quite some time 'cause if you had, you'd know that they aren't worth the powder to blow 'em to hell!
Gary
Chuck Gongloff (09-01-2016)
Moderator
the original question about deleting the regulator hasn't been answered-- yes, you can "delete" the regulator-- either jumper the inputs (there are many threads on here on which ones), or buy a plug-in connector that bypasses it, then just drop in any standard alternator.
it's a very easy swap.. I just bought the equipment and nice chrome powermaster alternator, and plan on dropping it in.
But if cost is an issue, by all means go with the regulator. your alt is likely fine, and will likely continue to perform fine. .
