C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Qs About Dashlogic/HUD/Wideband
Old 09-09-2016, 08:09 AM
BlindSpot
BlindSpot's Avatar
Received 1,364 Likes on 904 Posts
Default Qs About Dashlogic/HUD/Wideband
In an FI application using Dashlogic:
1. Does the AFR and other data project on a factory HUD?
2. What wideband are you using?
3. Assume the WB is installed in an added on Exhaust bung on the driver's side, before the O2 sensor? Or where is the best place?
4. Does the WB connect via one of the 0-5vs on Dashlogic?
Thanks,
Old 09-09-2016, 08:14 AM
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
Yes
AEM 30-0333 with wires added for analog out (isn't pinned by default on this particular model, uses an OBD/CAN output that connects to HPT really easily normally)
Driver side, pre cats, near factory O2 sensor. Had a bung added, $40 and half hour at exhaust shop
Yes, 0-5V out from WB controller connects to 0-5V in on dash logic
Old 09-09-2016, 09:41 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Yes, AFR can be on the hud, or dic or niether, just tell the dashlogic what you want. You get to setup 8 pages of displays.
AEM failsafe, analog into dashlogic.
In the extra o2 sensor bung on the ARH headers. Most aftermarket headers come with a specific spot for a wideband.
Old 09-09-2016, 09:48 AM
n_brio
n_brio's Avatar
can dashlogic also show lambda insted of afr?
Old 09-09-2016, 10:02 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
It can show whatever you want if you can do math. You have to setup the formula for turning 0-5V into AFR or lambda or % error or whatever you want.. if you can come up with a formula it can display it
Old 09-09-2016, 10:04 AM
Unreal
Unreal's Avatar
You can have it display "You are too lean" or "You are just right" if you wanted.
Old 09-09-2016, 10:07 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Mine says "stupid lean" all the time
Old 09-09-2016, 04:17 PM
BlindSpot
BlindSpot's Avatar
Maybe I'll just program my AFR output to say SMART or STUPID.
Old 09-09-2016, 04:18 PM
Unreal
Unreal's Avatar
And when at wot it can say Weeeeeeee! When going over 75 it can say slow down. The possibilities are endless.
Old 09-09-2016, 04:48 PM
BlindSpot
BlindSpot's Avatar
If I see a Scottsdale Cop behind me, then I'll have it say "Just Shoot Me".
Old 09-09-2016, 06:10 PM
Unreal
Unreal's Avatar
Sadly it doesn't have a pid for cop location.
timmyZ06 (09-11-2016)
Old 09-09-2016, 11:58 PM
SlowBusa08
SlowBusa08's Avatar
I have an alarm set to say "Shift Stupid" when I hit am approaching the rev limiter... gotta love it.
Old 09-11-2016, 09:24 AM
timmyZ06
timmyZ06's Avatar
detonation: knock knock who's there! true story! Im not even allowed to write on the forum what is says when im lean!!
Old 09-11-2016, 10:28 AM
BlindSpot
BlindSpot's Avatar
I have a feeling I'm really going to like Dashlogic.
Old 09-18-2016, 01:46 AM
jft69z
Support Corvetteforum!
jft69z's Avatar
It will also control your NPP exhaust valves if your car has it. Uses the mirror selector switch (Left, off, right) for the different modes. You can toggle the NPP/Dual Mode Exhaust between Open (loud), Closed (quiet) & standard OEM function.
Old 09-18-2016, 10:33 AM
GeneSch
GeneSch's Avatar
For some reason my oil temp reading on my DL is way lower then my factory display.
Old 09-18-2016, 10:34 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Actual vs calculated. Dash logic only has access to calculated, dic is wired to actual sensor
To Qs About Dashlogic/HUD/Wideband
Old 09-18-2016, 11:07 AM
BlindSpot
BlindSpot's Avatar
Wow, I actually surprised myself, I knew that... from schpenxel previous tutoring.
Old 09-23-2016, 01:49 PM
Woodstoc
Woodstoc's Avatar
I keep mine on a page that I set up that tells me boost and gear. Helps to know what gear I am in (automatic) when I decide to hit it. lol
Old 09-23-2016, 07:04 PM
BlindSpot
BlindSpot's Avatar
I've worked with the Dashlogic now for a couple of days. All I can say is...WOW... It's like a candyland. I had to stop playing with it so I could get my exhaust down to weld the WB bung in. That's at the welders, and my wideband should be here first of next week.
A couple of questions:
With 3 profiles x 8 pages on the DL, can you guys share some ideas how you are laying out the profiles and pages? Don't want to reinvent the wheel if the experts out there have come up with great layouts. I'm guessing you probably set up one slick profile and stay on that one?
Where are you going through the firewall with the WB harness?
Thanks, as always!
Quick Reply: Qs About Dashlogic/HUD/Wideband
