2010 GS Convertible Top Broken?
My day has finally arrived. I have a 2010 GS, original owner. My airbag light would come on simultaneously since day 1. I continued taking it to the dealer and they said they couldn't find the problem. I then received a letter last month, (not a recall) that stated they were aware the seat would catch and pull a wire triggering the airbag light. I put it into Boardwalk RWC Dealer for repair. When I went to pick it up, the convertible top wouldn't go down. They told me it had nothing to do with the repair for the airbag light. They quoted me $900 for the repair. They have had the car for two weeks now. They called me today and said they had fixed the switch for the top, then it broke again. Am I ever going to get the car back? Has anyone else had issues with their tops? Any suggestions. I'm about to flip my lid!
What are they saying is the problem with the top? There are only a couple switches and it is not really rocket science figuring out which one is the issue.
Can you possibly provide symptoms and DTC messages?
BROKEN SWITCH FOR CONVERTIBLE TOP 2010 gs
The dealer said there are 2 switches to make the top go up and down. They said the switch was broken. Well, it worked when I dropped it off! They called and said they had it working, then went to test it and it stopped working. They said if they found the problem by running a diagnostics check, they would call me when they figured out the problem. Well, no call back and two weeks later......
AL_Jazz (09-10-2016)
Race Car Tech
After reading another one of "those" threads, you no longer need to wonder why most C6 owners don't want to take their cars to the dealer for anything.
They may or may not be able to fix the original issue, but for some strange reason, but they will charge an arm an a leg even if they can't fix it. They usually break something else that was working perfectly normal when it was driven into the service bay.
I refuse to take my car to the dealer for anything. My car hasn't had the recall issues yet, but I will never go to the dealer to get the recall done on the car.(for the reson stated above) I know how to fix the ground for the low beam headlights, and also the air bag light as well.
The following 2 users liked this post by SilverC54me:
grandsportgirl (09-11-2016),
owc6 (09-30-2016)
I would suggest Abel Chevrolet in Rio Vista. They know how to repair Corvettes without robbing the customer. Their specialty..
http://www.abelgm.com/
They are Forum Sponsors and RichieRichZ06 is a member and sponsor..
don't put up with other "Stealerships"
Top will not move in either direction (and there is no DIC warning or chimes/etc.) if the windows have not been indexed.
Pretty well documented that the airbag and other connectors under the seat need to be cable tied together and free of any entanglements that may compromise the harness.
Check on your Regional Forum and find a competent shop recommended by the 'locals'.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
Please don't take any offense, but are you familiar with reindexing the windows? If that is the problem, you shouldn't owe them anything. Boardwalk is known for their sales, but Abel is know for their service.
My suggestion would be to contact Tim Boone. I bought my Corvette at Boardwalk. Sales can help you if you are dissatisfied with the service department. I no longer use the service department at Boardwalk but still see Tim Boone at various Corvette events.
Candy
Top broken
I am really sorry this has happened to you. I don't know if the Bureau of Automotive Repair can help you or not. It sounds like they are more after the fact.
http://www.dca.ca.gov/acp/index.shtml
