FS: LS7 Z06 heads pair, LS7 oil pan, LS7 oil pump
FS: LS7 rocker arms
Item Location (City/State): San Ramon, CA 94583
Price: $165
Description: stock LS7 rocker arms $165 shipped to the lower 48
1 pair LS7 heads with 22K miles $1K shipped to CO/TX and states west of them. Add $25 for states to the East of them.
need the guides replaced and I would suggest springs/keepers/seals/valve job and/or porting at the same time.
Price: $165
Price: $1000
Description: LS7 heads pulled off of a 34K mile GM warranty long block. Aftermarket cam was going bad and it had 10 bad lobes making oil pressure wonky and engine noise! I'm keeping shortblock to rebuild.... heads gotta go. They are complete with TI intake valves, stock exhaust valves, stock springs/keepers/lash caps on the intake valves. They should be gone thru and have the guides replaced at the minimum with a valve job plus new exhaust valves. $1000
Add $150 for all rocker arms
$60 shipping/pair insured via FedEx Ground to the midwest insured and $80 shipping anywhere east of Kansas.
LS7 oil pan in perfect condition with all bolts $225 shipped to midwest and $235 shipped to the East Coast. Cleaned in a parts steam cleaner. Windage tray add $10. Pan has the pickup tube incorporated into it already. Needs a new gasket as front rubber is torn. I can provide new one for $50 with pan purchase.
Also fits LS3 Grand Sport and LS9 engines
LS7 oil pump- used $40 shipped via USPS Priority Mail ground
Price: $1000
Is is the oil pan still available?
Price: $1000
Price: $1000
It's important to mention if the oil pan has the threaded bosses on the side for the newer style (side mounted) oil cooler. If it doesn't than technically it won't be a direct swap for a LS9 or 2011 and newer Z06.
1 complete LS7 head stock head available and the rocker arms
Everything else sold. Thx
1 pair of stock LS7 heads available $1K shipped pair add $25 for states East of CO/TX as cost goes up.
1 single stock LS7 head availalable $525 shipped
LS7 stock Rocker arms $165 shipped ($150 shipped with purchase of heads)
