RPM 4l65, TT, and diff
Transmission: Level VI 4L65/70E Transmission with 300M output shaft, 2.85 6pinion 4l60e planet, Deep Trans pan, Transbrake, A4 to C6 diff adapter plate, A4 conversion brace, Extreme duty torque tube converter drive plate.
Differential: C6 Z06 Differential: 3:42 gear, fully micro polished, 300M LH shaft, 300M RH Shaft and gear, HD Clutch Pack and Preloaded Springs. Quaife Torque biasing differential upgrade
Torque Tube: Extreme Duty DSS Prop Shaft 3inch 1000RWHP, DSS Urethane couplers, torque tube bearings and slingers, corvette SFI flexplate
Coan converter 4200 stall speed and setup for a 400 shot.
I don't want to separate but if i have enough people interested I will.
I also have a iron block 6.0 with 243 heads done by TEA. The motor is built for boost and is brand new zero miles on the new rebuild.
7500 for the Trans,diff,and TT
5000 for the motor
5000 for the motor
5000 for the motor
5000 for the motor
