what would a aggressive tune do to a automatic 2008 corvette?
Forget about HP gain, since your only going to see about a 15hp gain.
Instead, focus on the point of the auto trans tune, and de-hobbing what the TM is holding back, which makes a huge difference in itself instead.
so the tune would make the car shift faster and what else would it do?
It seems you are aiming at performance at this stage. I recommend you change headers and exhaust if not NPP and then tune it. You will see a much larger gain than spending the money right now. What kind of tune did you have in mind?
an aggressive tune. not sure which ones are out there but the best one for overall tuning of the car including bringing responsiveness to paddle shifters
Torque Management holds back a lot of power especially in 1st and 2nd gear.
I have mine turned off in the tune ....it's a seat of the paints gain but..... you could break stuff ........
I also have a TCM tune , it shifts faster and harder than stock when you are on it but shifts fine when driving normal
If you have not added or plan on adding any bolt on mods, headers , cold air intake etc don't bother spending money on a dyno or street tune .
Get an INTUNE, load the 93 octane tune , load the TCM tune , set the trans tune to firm , turn off torque management and buy a Vitesse Throttle Controller, you will be amazed at the transformation
Dave
Dave
Dave
Dave
Iceman007 (09-26-2016)
I would at least get a less restrictive flowing air intake and then get the engine and tranny tune. A throttle booster would complete the package nicely.
Sorry, didn't realize that you have the LS3. Your air intake is fine!
Dave
Dave
Dave
Dave
my 08 automatic gets scary fast when i press the gas all the way to the point where tractin control has to step in on the display sometimes. im talking 0 to 100km in 1st gear
lol and ppl are talking **** about automatics? this car bone stock is just a monster in full throttle sport mode. i think traction control saved me today lol. coz my manual friend was saying torque converter makes autos lose power but u can turn that off in tune? thats amazing lol
No, an auto thans has more power loss that a manual in the drive line, due to the torque converter that is needed between the motor the the trans (what acts like the clutch on a auto trans). So an auto trans, you lose around 10 to 15HP through the drive line because of the torque converter.
Now having said this, in 1/4 mile strip racing, you can't shift a manual as fast as an auto trans can self shift, so auto's, even with slight power loss, are faster than a manual trans car in a quarter mile run, if everything thing else on the car is the same.
Where the manual shine, is on a road coarse, since it with a manual, easy to be in the right gear for corner existing instead. Hence the auto trans in the Vet is not a sequential transmission, and is not going to let to bang down gears even close to the point of red line as you are coming down (press and wait instead)
Torque management can me turned off in the tune ... you will feel what the car really has but like I said above , you can break stuff with it off
The parasitic losses in an AUTO are higher than a manual but I am an old Stick guy but I love my Auto .....
I am the Red one in this video and that's a McLaren , I am pulling away from in that first turn ......
Dave
The OEM transmission calibration in the 08 is absolutely terrible. It makes the car drive like your grandma's Buick by shifting it into 6th gear at 30mph and then not allowing it to downshift when you push on the gas pedal.
Getting the transmission tuned will yield the most improvement. Doug at ECS has a really good trans tune that I would recommend.
Dave
if you get a good tune, you don't need that throttle booster crap
Not unless you wanted the ability to adjust your sensitivity , with a tune you are stuck with whatever you get .......
I use mine all the time , dial it down in the rain , bump it up a bit when racing and click it up to sp9 when I want to make noise and have fun .... try to do that with a tune ......
Dave
Dave
damascus1986 (09-20-2016)
started with the diablo 93 tune in my 08 auto, getting rid of TM just makes the car so much more fun. had some maintence done at a local shop went ahead n switched to a custom tune, not sure how much HP i gained but there was a definite TQ gain over the diablo. just sent it back a month ago for headers and a retune and ITS AWESOME . cool thing about the diablo was i was able to unmarry it and resell it.
Note, on a Sequential transmission, you don't need to use the clutch for either up shifts, or down shifts. So the clutch is used to get the car first moving, and then on hard down shifts, the clutch is used so you are not over rev'g the engine on the hard braking into the corner a major multi gear down shift.
Hence on a 2 stroke, you can over rev a touch on the bang down, but on a 4 stroke, it a fast way to smoke a motor isntead (quick lesson you learn when you move up from shifter Karts, into FF or FM cars next/have to learn to bring the clutch back in play around the track for quick bangs down into hair pins).
https://youtu.be/Fjlm9BoaiZg
Dcasole (09-24-2016)
Even with a TCM tune, the vet auto is not going to bang down this hard. Hence notice on some of the down shifts, the clutch is put into play so the downshift does not over rev the engine on the bang down isntead.
Dave
