Vitesse Throttle Controller Problem?
Old 09-19-2016, 04:59 PM
UsernameProtected
UsernameProtected's Avatar
Default Vitesse Throttle Controller Problem?
Hi all.
I have a 2016 Stingray that I've installed a Vitesse Throttle Controller on about 4 months ago. Mostly I've had no issues with it...though on two prior occasions the car has gone into "limp mode" for an unknown reason. During both of those occassions shutting the car down for five minutes or so resolved the issue.
This afternoon I had another "limp mode" experience, and it makes me think the Vitesse is causing it. At start-up, the car indicates "reduced performance available", and active rev match is not available. Shutting the engine off, opening and closing the driver's door, then restarting the engine did not clear the message...but....
Shutting the engine off, then selecting the Vitesse to SP0 (no throttle amplification), then restarting the engine caused the "reduced performance available" message and associated nuisances to go away...until...
I selected any level of boost from the Vitesse, which caused the car to immediately go back into limp mode. I repeated this process three times, and each time the car would immediately revert back into limp mode.
I'll contact Vitesse about this as well, but I thought I'd post here and ask if anyone has experienced similar.
Thanks in advance. I'd sure hate to have to go back to driving the car without the Vitesse.
Old 09-22-2016, 12:55 AM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
I haven't had any issues with mine, it's been in for ~10 months now. I'll be curious to hear if it is the Vitesse causing your problems, it sure sounds like it. if you remember, an update would be great!
Old 09-22-2016, 10:51 AM
Flame Red
Flame Red's Avatar
Received 1,084 Likes on 656 Posts
Ordered mine more than a week ago and still nothing. Gee their shipping is S L O W.
Old 09-22-2016, 05:09 PM
VAVetteC7
VAVetteC7's Avatar
Originally Posted by UsernameProtected
Hi all.
I would re calibrating the accelerator pedal servo.
1) Set controller to SP0
2) With car off, not in acc mode either, push the accelerator pedal to the floor, hold it their and push the start button, wait for 2 to 3 seconds and let off the accelerator. This will force the ECU to re calibrate.
3) re calibrate the throttle controller
4) take for a test drive and hopefully your problem is solved.
Old 09-23-2016, 03:58 PM
TNSQUIRE
TNSQUIRE's Avatar
contact them directly. I had the same issue. As soon as I sent a status request they sent it out that day.
Old 09-27-2016, 05:53 PM
Roadrogue
Roadrogue's Avatar
I had same problem and recalibration fixed it. Also took main unit out from behind the rug in case it was getting hot.
VAVetteC7 (09-28-2016)
Old 09-28-2016, 07:49 PM
VitesseMotorsports
VitesseMotorsports's Avatar
Yes, it's important to re-calibrate the Controller once every few months.
Also, very important not to place the main box under the carpet or next to the Transmission wall... too much heat down there.
VAVetteC7 (09-29-2016)
Old 09-28-2016, 09:26 PM
eddie-d
Support Corvetteforum!
eddie-d's Avatar
I think the Vitesse unit is great. So, if you don't recommend installing the main box under the carpet or next to the Transmission wall due to heat where should we place it? the wires from the pedal to the box are not very long and this limits where we can actually place it.
Old 09-28-2016, 09:57 PM
spearfish25
spearfish25's Avatar
I Velcro'd under and then gorilla taped over the box directly under the steering column. It's a nice smooth surface that everything sticks well too.
Old 09-29-2016, 10:32 AM
TNSQUIRE
TNSQUIRE's Avatar
I just put a piece of velcro on the back of the box and stuck it right to the carpet. Works fine and out of the way.
Old 09-29-2016, 06:35 PM
VitesseMotorsports
Yes, right under the dash plastic , under the steering wheel column.
Old 10-01-2016, 05:07 PM
Dan4time
Dan4time's Avatar
Default Regarding recalibration...
Hello, I purchased the controller about one month ago. It is fantastic for "seat of the pants" performance. Regarding the re calibration, do you mean just following the original set up instructions when I first installed the controller? Also, I believe you said every two to three months?
Thank you in advance.
Dan
Old 10-01-2016, 06:13 PM
VitesseMotorsports
Yes, the same calibration you did the first time, it's suggested to do it every 2 or 3 months.
Old 10-01-2016, 09:53 PM
falconhulk
falconhulk's Avatar
I went to order this controller tonight a saw the giant disclaimer to not use it on the street. I did not order it. I am on the fence now.
Old 10-01-2016, 11:00 PM
oemtech
oemtech's Avatar
That disclaimer is Vitesse doing a CYA..
Old 10-02-2016, 09:39 AM
Flame Red
Flame Red's Avatar
I wish I had known this before I ordered mine.
Old 10-02-2016, 11:33 AM
Patches
Patches's Avatar
I've had mine in since Dec., '15 and have never had a problem with it or had to recalibrate it. Easily the best mod I've done on my C7 and one of the best I've done on any Vette I've owned and that's a bunch of mods.
To Vitesse Throttle Controller Problem?
Old 10-02-2016, 12:09 PM
falconhulk
falconhulk's Avatar
Oh yeah, I get that. But in covering their *** it kind of puts a spotlight on my *** if I get into an accident.
Old 10-02-2016, 03:33 PM
Patches
Patches's Avatar
No more than if you put high performance brakes or a supercharger or a ported throttle body on. It doesn't make the car harder to drive just better.
Even the service writers at the dealership doing warranty work on mine don't care and even ask where they can get one for their car.
Old 10-10-2016, 05:44 PM
oemtech
oemtech's Avatar
Yes, but I venture to say that if push comes to shove... your SA will speak the party line and side with GM and/or the dealer.
Now you can get into a pissing contest with them via the Magnuson Moss Act in they have to prove the aftermarket part caused the failure. Good luck with that.... as you will need deep pockets and a good lawyer.
Bottomline.... you play you pay! So, if you want 100% warranty leave it stock and no mods what so ever.
Quick Reply: Vitesse Throttle Controller Problem?
