427 LSx, Huron Speed Twin Kit, Alky Control 1250+ RWHP Combo!
Former Vendor
Personal item for sale:
As much of a bummer as it is, it will be beneficial to myself and my business to part this amazon project out now to be able to jump on a new opportunity that will help expand the business.
This build was just completed, so fresh that the car has not even ran.
The engine fired a couple times but some electrical issues in the car pointing at a previous Viper Alarm system seemed to create some havoc on the computer. With that being said, everything below has zero miles on it, all fresh and all still full of warranties!
427 Lsx Long-block
-TMS Forged 4340 4.000" Crank
-TMS Forged 4340 H-beam Rods
-Diamond Pistons
-ARP Main Stud Kit
-ARP 6-bolt head stud kit
-Dual Stainless Ring Package
-24x
-Target 10.0:1 CR
-TFS 245 6-bolt heads (Cathedral Port)
-Melling High Pressure Oil Pump
-Chromoly Pushrods
-John Bewley Spec'd Turbo Camshaft
-Dual Valve Spring Kit w/ Titanium Retainers
-Billet Timing set
-TMS High RPM lifter Set
-GM Rockers
-GM Lifter Trays
-GM Head Gaskets
Above engine will also Include the correct Valley Cover, along with a LS2 Front Cover.
$9995 plus the freight to you.
SOLD!
Huron Speed All-Out Twin Turbo Kit
-Kit includes ceramic coating in customer Ceramic Gold/Titanium Mixture on all hot-piping (not shown on X-pipe but will have done for you prior to shipment) Ceramic will have some scratches from installation/removal
-Twin Comp Billet CT4 7479 Turbos, .96 a/r
-Twin Turbosmart Hyper-gate 45 waste gates
-Bell FMIC with all shroud and brackets
-Cold Side Pipe and Inlet pipes Powdercoated Candy Red (Can coat any color you like for slight increase in cost)
-Charge tubing will supply both our hard stainless version as well as the thick silicone for the buyer.
-All Oiling included with feed line set-up including Bolt On Oil Block, Drain Lines, etc.
-C6 Oil Pan included, pre tapped with drain fittings already installed
-Fabricated engine mounts and Hinson Shorty Poly Mounts
-CTS-V AC Compressor and our full AC Kit (will still require you to assemble the lines but everything is included!)
-XS-Power 50mm BOV
-HSP Full 3" Muffler-Less Axle Back system ceramic coated
-Cold side pipe will also include the threaded IAT Sensor required and is pre-drilled for a dual nozzle Alky Control Kit
This sell on our website here: http://shop.huronspeedproducts.com/H...-04-hsct55.htm
for over $11,000 plus shipping with all of the options, components and upgrades.
$8995 plus ship
-Will Include an Eboost 2 (60mm White/Black) with lines for $500 with purchase of kit.
*If you purchase with the Engine above together, we will include the required manifolds to fit the 6-bolt heads, as well as throw in the Alky Control Kit below for Free!
Alky Control Dual Nozzle C5 Methanol Kit (Twin M15 nozzles, MAP reference)
-Will include my WW Bottle with purchase as well, already set-up. System never used or wired.
$575
$18,500 for the package of everything above including the 427 LSX long block, complete and fully optioned out Huron Speed Twin kit w/ 7479's, Alkycontrol dual nozzle kit, and Eboost 2 controller set-up!
My engine is on the right
Stock photo of the kit, but shows what all you will be getting!
427 Lsx Long-block
-Diamond Pistons
-ARP Main Stud Kit
-24x
-Target 10.0:1 CR
-Chromoly Pushrods
-Billet Timing set
-GM Rockers
-GM Lifter Trays
-GM Head Gaskets
SOLD!
-XS-Power 50mm BOV
$8995 plus ship
$575
Are you selling that coolant tank? I may be interested.
Do you have a dyno sheet? I see you posted 1250 RWHP so thats over 1400 at crank. Very impressive but would like to see sheet b4 I make offer and also how many lbs boost you had it set at.
Former Vendor
Billet 7479s on a 427 has no problem making a whole bundle of power extremely easily.
Former Vendor
Back up! Engine coming out today, most all of the turbo kit off and ready to package up, will get some photos of everything together once it is all off the car this weekend!
