C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] sway bar end links
Old 09-20-2016, 01:19 PM
LMB-Z
LMB-Z's Avatar
Default sway bar end links
Can someone please tell me how to tell if my end links are worn out? I keep hearing noise coming from rear end. Not sure if its end links, worn out lowering bolt rubber, rear end noise, or what.
Old 09-20-2016, 03:58 PM
Sox-Fan
Sox-Fan's Avatar
Sounds like end links from here in South Carolina.
Seriously, unless someone is there to hear it, how are we going to know? Jack it up, grab the end links and yank. Do they make noise? Do you see rusty or dirty streaks? Wear marks? Now inspect the right height bolts. Are the rubbers shot/gone?
Point is, you can trouble shoot this a hell of a lot better then anyone on the forums half way across the country.
LMB-Z (09-20-2016)
Old 09-20-2016, 10:36 PM
LMB-Z
LMB-Z's Avatar
LOL...true. Just looking for some insight. Thanks
Old 09-20-2016, 10:39 PM
Mike's LS3
Mike's LS3's Avatar
When do you hear noises? Slow speeds over speed bumps? Turning onto a driveway? Is it a popping noise?
LMB-Z (09-22-2016)
Old 09-21-2016, 10:28 AM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Rear axle nuts also loosen and can make a clicking noise. They take either a 33 or 34mm socket. I went to an AutoZone that had both, they let me try and I bought the one that fit best. Original torque was ~130#ft but now GM says 160#ft. on Most wheels these can be checked/tightened by just removing the wheel center cap.
LMB-Z (09-22-2016)
Old 09-22-2016, 11:01 AM
LMB-Z
LMB-Z's Avatar
Originally Posted by Mike's LS3
When do you hear noises? Slow speeds over speed bumps? Tuning onto a driveway? Is it a popping noise?
Seems to be while turning right at slow speeds. Have checked axle nuts and they are tight.
Old 09-22-2016, 11:04 AM
LMB-Z
LMB-Z's Avatar
Thanks Dave...checked axle nuts....socket cost me $17. They are as tight as I can get them...lol. I just don't really know how to check the end links to see if they are bad.
Old 09-25-2016, 12:56 AM
Mike's LS3
Mike's LS3's Avatar
I have replaced my front sway bar end links twice and rears once since new, currently with 72k miles.
Also, while parked idling, try turning wheels full left to right. If you hear creaking noise it could be you rack and pinion bolts to frame loose.
Old 09-25-2016, 11:38 AM
Brandon619
Brandon619's Avatar
Buy a quality set of end links like LG Quiet End Links. I installed a set of four on my little base C6 build.
LMB-Z (09-25-2016)
To sway bar end links
Quick Reply: [Z06] sway bar end links
