P51D Mustang LS1 Engine
Pounder (09-22-2016)
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Seen that before. IIRC it's a 2/3 scale. Pretty neat though.
Received 19,291 Likes
'20-'21-'22-'23-'24
That's a good looking plane they built. Pretty that they used an LS1 engine for it.
I got to fly the Merlin powered original! One of the greatest experiences in my life. It was fitted with dual controls. Her name is Betty Jane.
1/4 mile/AutoX
hope this is not a dumb question, is it air cooled ????
Received 1,679 Likes
For you guys who are unfamiliar with piston aviation engines, they are designed to be run at 75% power continuously. That is tough duty for an auto engine. They probably run this P-51 replica at 5,000 RPM for takeoff and then something like 4,000 RPM for cruise. (there is a also a gearbox to slow the prop RPM to something less than a max of 2,500-3,000 or so)
For comparison, the fuel injected IO-540 produces 300 HP for takeoff and 225 at cruise at 2,500 RPM and it needs 540 cubic inches to do that.
1/4 mile/AutoX
Do you know how this LS1 engine would cope with oil control, etc during high G maneuvers? I would think this plane would be used for rolls, vertical climbs, maybe even upside down....I sure would like to know how they're keeping the oil pickup from sucking air. I've been in a small plane that could dive with enough negative G's that anything not strapped down was floating....I would think the oil in the sump would do the same.
But will that work if the engine is laying on its side or upside down? You would think that if somebody had the ability to put together such a specialized airplane, they would probably have an answer to the oiling question. It would be cool to find out how they did it. I hope it works out for them because it is a cool plane and there is a LOT of money tied up there.
I don't know..... I'm not sure if an LS based motor is the best idea for an aviation application, especially when you see what aviation certifications are on everything from the motor to the air conditioning compressor and everything in between.
The lifters aren't in the valley in on a ls1 they are underneath it. There is a guy making V12 LS1's for this purpose, by welding parts of two engines together.
The sound of the V8 is all to familiar. The sound doesn't go with the aircraft for me.
Awesome video though. Thanks!
