Do OnStar lights on mirror dim at night???
I recently had my OnStar module replaced on my 2016 Corvette and the Onstar Lights on mirror stay bright even at night. Not sure if this was the case before but I notice it now. Can you guys check to see if your mirror lights dim when headlights come on? Thanks!!!
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Mine dim. Is the dash light control turned up to high ?
Mine do not dim with the dimmer switch. I think they are distracting and annoying. I pulled fuse 26 from the engine bay fuse box, but the lights stayed on. Ended up disconnecting the power to the mirror (1LZ.) Beware, however, if you disconnect the power on a 2LZ or 3LZ car you will lose the auto dimming feature.
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
Red and Blue Lights Blocked With Black Tape and Hole Punch!
