Loud exhaust - help
Loud exhaust - help
I'm buying a 72 350 with super comp headers and side pipes.. No inserts.. Very loud. :-)
I'm going to try adding some STS or Sweet Thunder inserts to see if it can quiet is down enough to not be an issue driving around own as that's mostly where I'll drive her. Not sure what to expect here..
I heard someone mention they had some kind of dual mode exhaust.. you can flip a switch to go from loud to quiet.. Maybe something similar to bi mode exhaust on newer vettes.. but something I can do with a 72 that has side pipes..
I love the look of side pipes and don;t want to get rid of them.. so looking at my options.
Any thoughts or suggestions?
Thank You
Thank You
Thank You
Thank You
I too have loud side pipes but mine do have mufflers inside, as a first step I'm going to slide them out and cut them open as I suspect the sound deadening mat has broken up over the years and is now ineffective, if so I'll repack them and weld them back together.
Graham
I don't have any experience with side pipes but if it's just a matter of unbolting the back half and dropping in an insert I'd go that route. Found this article just now online. This company (Dougs) offers 3 inserts for their product. Installation of a full new set of headers/pipes looks pretty easy provided you've got access to a lift. I might just have to look into it for my 72. I really dig the look.
http://www.corvetteonline.com/tech-s...dougs-headers/
try the sweet thunder 2" inside diameter insert
Received 3,043 Likes
St. Jude Donor '05
Left side earplug enjoy your hotrod
https://www.youtube.com/watch?v=H9FSNNJn8qg
this is a pretty built 383 with maxflow inserts, not super loud, but should give you an idea of what to expect vs yours with straight throughs.
