Side splitters?
Side splitters?
I just ordered a 2017 Z06 Friday.and was wondering if the side splitters come with the car or do I have to order them it a 2LT
thanks tony
thanks tony
Z07 or carbon exterior package I believe. Or do what I did. Buy the C7carbon pieces and/or APC pieces.
Side Skirts - C7carbon $700
Front Splitter - APC $455
Stage 3 winglets - GM $250 (used from Cforum member)
Total - $1,405
Total - $1,405
upcharger (09-26-2016)
The 3/4 side skirts are now standard as pictured below (Stage 1).The 2LT package has nothing to do with the optional Stage 2 and 3 Areo Package side skirts as shown in the second picture, which is the Stage 2 package. Note the Stage 2 and 3 side skirts are the same, only the spoiler and front splitter winglets are different. Stage 2 has the rear spoiler extensions and smaller splitter winglets, and the Stage 3 adds the rear center spoiler Wicker Bill and the taller front splitter winglets.
Cars pictured are the 2017 GS, but the 2017 Z06 is supposedly equipped the same way with regards to the Areo Packages... and the Z07 has the Stage 3. Hope that this helps.
isn't ZO7 $6000 Ill just get the carbon flash ground effects package it only $3000 that's a bargain ?
cvp33 (09-26-2016)
do you have a link for the front splitter please?
Pissed off because you need to spend money or pissed off because you have to drill holes?
If you ordered the GM aero, then the dealer would be drilling the holes.
If you order aftermarket, then you can use double sided tape to attach if you so choose (there are many threads on that).
Probably not too late to cancel or change the order. Do your homework better and reorder what you want, or order a different car......
Less expensive to do it yourself. I got all the CF bits for stage 2 on a non Z07 Z and it was $6k worth of MSRP option cost over the 3LZ.
I do think a G was for interior CF.
went Tuesday to the chevy dealer and was able to get the front and side splitters and rear spoiler up grade.now I just have to wait. I know some of you we worred so im giving you a heads up
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Glad it worked out. You were fortunate. Way better with install at B G. That way, the entire enchilada is covered by the warranty.
