just filled up tire pressure
tire pressure was 25 psi cold, bumped it to 30 cold. however in the corvette display its not all accurate like front left is 29 while front right is 30. is that fine? if they are a bit off? also how can i change KPA to psi in the corvette display
That's not a problem. I think the accuracy of the TPMS is ±1 psi anyway. I always try to make sure I make all the tires the same using my digital gauge, and it's incremented to 0.5 psi, still with a tolerance of ±1 psi.
oh ok cool. off topic but sometimes when i accelerate hard traction system comes on in dic and i feel like im losing control and it saves me lol. is that normal too?
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
You ARE losing control. That's why the "nannies" are there: to save you from yourself. I realize this sounds funny, but it's not. People used to kill themselves when they lost control of their high performance cars that had no "nannies." Count yourself lucky and WADR, learn your car before you overpower the "nannies."
The laws of physics can only be played with so much with technology, and then it's crash time.
See this and ask yourself if you are "feeling lucky today": https://youtu.be/pGjT2rYv1B4 (from Z06 thread---https://www.corvetteforum.com/forums/c7-z06-discussion/3882412-z-vs-z-butt-pucker.html)
michellin sport tires, got them in spring. still lots of thread. but it traction coomes sometimes not always. only when i bash in the gas sometimes lol. and today i filled them up to 29-30psi cold. they were about 27 before
Received 3,633 Likes
2016 C6 of Year Finalist
Whaaaaat???
Kilopadcal. Change your DIC.
St. Jude Donor '16-'17, '19
Reading discrepancy
So... I have two very good gauges that I know are very accurate... and I have put 30 psi in each tire. However, the DIC tire monitoring (TPMS) shows 3 pounds less (27). I'm pretty confident that the TPMS is reading consistently low and I can mentally keep track of where I believe pressures are when tires are heated up.
Question to the Forum is.... "Is there a way to easily change (calibrate) the TPMS or DIC so I can get them in-line with what I know are accurate pressures (measured by the gauges)?
If you go to US/english vs. metric (it's been so long since i changed that setting, I forget the actual wordage), it will change Kpa to Psi, but it will also change Kph to Mph, and all the attendant measurements. You can't pick and choose which are in one and which are in the other.
A good hand-held gauge is a must when filling tires; the car (and the read-out on the DIC) doesn't sample often enough to be even a close to reliable measure.
A pound or so between one tire and the others is nothing to worry about, but keep in mind this time of year, temps are falling, so filling up to barely 30# is going to be under inflated tomorrow. You are going to be better served with slightly over-inflated (cold pressure) tires than under.
Actually,that is my experience, all year round, anyway.
I forgot to tell you how you change this.
The right side dash buttons. OPTION, scroll to english or metric, then RESET.
DANG, and it's kPa.
DANG, and it's kPa.
