What does the "Ostrich 2.0" do?
Their website doesn't give a very good description. I guess they just assume everyone knows this stuff?
Will it fit my 85? I see 86 listed.
Is the 85 different?
I gather it is a piggyback device from looking at it. Like a tuner.
What can you do with it?
I'd personally re-pin the harness to a '165 ECM (86-89) and use that. The ARAP code used on the 1989 vette is a good starting point.
The Ostrich replaces the ROM chip inside the ECM/memcal. This allows you to change calibration in real time. (i.e, while the car is running).
Mike Davis wrote a nice article on swapping the '85 ECM to the '165. I'd look into that if I was you.
-- Joe
confab (09-26-2016)
The '85 is a 1 year only ECM, with limited calibration options.
I have a question too. I bought the Ostrich
-- Joe
-- Joe
I have an 85. It has a 870 ECU with a 24 pin chip. It can read this chip but not burn it. I had to add a G2 chip adapter so that I can use the 28 pin chips from the 165, because that is what the APU1 can burn. I don't know if the Ostrich is the same.
I am learning tuning on the 870, but plan on moving to the 165 at some point. The main problem with the 870 is you only get a datalog packet every 1.2 seconds, where the 165 gives you one every .1 secs. So you get a poor picture of what your ECU is doing in an 870.
However, again, the 1 year only '85 ECM isn't as popular so I'm not sure how much digging one must do. I wouldn't go out of my way to try and read your stock chip though.
I can't think of any real logical reason to keep that ECM in the car, when the '165 is a straight forward swap.
I don't even do much with any of the stock ECM's any more. I use Megasquirt on my stuff, but you can still build a mean street car using a '165 and a Ford MAF.
-- Joe
Usually reading the original prom isn't a concern because most of the broadcast masks are published over at diy_efi, so most people just download the stock bin and tune it.
-- Joe
-- Joe
