Recommended Header/Collector Gaskets?
I think I need to replace my header and collector gaskets. Which type/brand do you all recommend?
Fel-Pro blue steel
Header gaskets
I would agree with the earlier post. I have been using the soft Copper on my car and have not had a leak ever. They make a soft aluminum set that is slightly thicker if you have room for it and it was a bit cheaper when I bought mine.
I have copper on my collectors. I had fel-Pro 1404 I believe they were but, no one had them. I took a chance on the Percy's this time. They are hard to slip in without taking bolts out mine are 3/4" I tried putting longer bolts this time but the sweep of the pipes stopped that.
