2016 C7 at NCM 209.9
NCM 2016 C7 A7s Hawk pads everything else stock
https://www.youtube.com/watch?v=M-DoXiRU-UY
Heated and went into limp mode on 3rd lap!
Jim
Jim
davidwarren (09-26-2016)
2019 Corvette of the Year Winner
St. Jude Donor '15
what were the ambient temperatures?
Given that you have a manual.....what has been said before would have suggested that wouldnt happen.
I only saw an instance or two where you really wound it out to the red line....there were also a couple of good long straights......
Nothing I know of predicted the car would go into limp mode and all the bells and whistles would go off. I did not expect it. I think the 1.7 Gs had something to do it.
The Cosworth program said car was on the gas 35% of the time and on the brakes 15% of the time. There is no need to go to red line before every shift. I thought that was very interesting.
Jim
Cruise-In II Veteran
Cruise-In III Veteran
Do you have the secondary radiator?
hey Jim,
Anthony Coberg here, do you have the GMPP secondary radiator installed? It's standard on the 2017 manuals. I just picked up my 2016 and after the break in had the secondary cooler installed... sorry about limp mode, that sucks
Hi Jim, That's sinks, mine got so bad I could not get one session out of it if it was over 85 degrees. GM bought it back and I just picked up a 2016 Red 1LZ with the Z07 package and PDR/Nav 93K sticker for 75K. It's on the way Callaway for the SC757 package.
Frank
Frank
Jim what does the pdr show for fluid temps when it went in to limp mode? I'm curious which fluid overheated.
Jim can you post the full video with a screenshot of the PDR data. I'm curious how the car behaved when it went in to limp mode. Specifically did it fall on its face instantly or just roll off some boost.
My post disappeared. What was up with active handling flashing during the brake zones while in PTM Race? Then about a third of the way into the lap, the PTM mode was disengaged.
Jim
Jim
At turn 10 the car immediately slowed down to about 30-40 MPH, flashers came on, DIC said: LOW BRAKE FLUID, LOW OIL PRESSURE, HIGH OIL TEMP, Etc. It was important to watch for other cars in the red group until we got off track so I can't tell you what else it said. The car also called OnStar!
The Cosworth program showed:
Max water temp 230
Max oil pressure 51.1
Max oil temp 273
Max trans temp 167
If you notice 2nd gear was used a lot. Running the track in 3rd is slower but there are no issues.
I hope this is what you were asking.
Jim
I'm surprised you hit limp mode with those temps. None seemed to exceed a previously documented threshold. Were fluid levels ok? Low brake fluid can throw wild codes.
That doesn't sound like overheating. You've got a lot of non temp related things going on and the fluid temps don't look that bad. The oil temp is high but it's not near the shut down limit.
It kind of sounds like an electrical issue of some sort. Loose ground or battery cable? I had an exhaust leak melt an electrical connector under the motor on mine.
Keep us posted and I hope for a quick fix.
I am 72 years old and have had a great career but it is time for me to stop. I will be at the 10/10s event in a couple of weeks and that is it for this car on the track. My bones are getting less dense due to advanced prostate cancer treatments and my very supportive wife and doctors say it is time to quit.
Everything must come to an end.
Jim
I am not good at getting and posting the data but here is what I have:
Max water temp 230
Max oil temp 273
Max trans temp 167
Jim
Max water temp 230
Max oil temp 273
Max trans temp 167
Jim
This is 100% an electrical problem. The braking system (low brake fluid) and the engine oil pressure warning system (low oil pressure) are 2 totally unrelated systems. The fact that you got both of these unrelated warnings as well as other warnings simultaneously tells us the communication from the data bus was lost for those systems. Generally when this happens the affected system defaults to the worst case alarm to "scare' the driver into a immediate reaction.
Have them look for a lose or water soaked connector at the PCM or as Poor Sha said burnt and or bare wires on the harness between the PCM and the engine sensor harness that feeds all of the engine sensors.
Let us know what you find out.
Jim
dar02081961 (09-27-2016)
