(2) Prototype Huron Speed C5 Twin Turbo Kits For Sale - COMPLETE!
Former Vendor
(2) Huron Speed Twin Turbo Kits for sale here
-Both of these were installed on cars for fitment purposes, R&D, so they may have some minor run time, some scratches from install/removal, etc however are both in complete, 100% working order and include our full warranty to the purchaser!
Kit #1:
-Kit includes ceramic coating in custom Ceramic Gold/Titanium Mixture on all hot-piping (not shown on X-pipe but will have done for you prior to shipment) Ceramic will have some scratches from installation/removal
-Twin Comp Billet CT4 7479 Turbos, .96 a/r (Have the require minor grinding done on the compressor housing already!) Polished Covers. *No Run Time*
-Twin Turbosmart Hyper-gate 45 waste gates *No Run Time*
-Bell FMIC with all shroud and brackets =
-Cold Side Pipe and Inlet pipes Powdercoated Candy Red (Can coat any color you like for slight increase in cost) Scratches from multiple installs/removals
-Charge tubing will supply both our hard stainless version as well as the thick silicone for the buyer.
-All Oiling included with feed line set-up including Bolt On Oil Block, Drain Lines, etc.
-C6 Oil Pan included, brand new from GM
-Fabricated engine mounts and Hinson Shorty Poly Mounts
-CTS-V AC Compressor and our full AC Kit (will still require you to assemble the lines but everything is included!)
-XS-Power 50mm BOV
-HSP Full 3" Muffler-Less Axle Back system ceramic coated (Red Tips)
-Cold side pipe will also include the threaded IAT Sensor required and is pre-drilled for a dual nozzle Alky Control Kit, Coated Red
$7995 plus ship *Can remove some above components, change colors, re-coat, etc and adjust the price if desired*
Kit #2:
-Kit includes ceramic coating in custom Ceramic Gold/Titanium Mixture on all hot-piping (not shown on X-pipe but will have done for you prior to shipment) Ceramic will have some scratches from installation/removal. Downpipes do not have the flex installed and have some brackets attached.
-Twin Comp Billet CT4 5865 Turbos, .58 a/r (Have the require minor grinding done on the compressor housing already!) Red Covers. Triple Ball Bearing, Only idled, maybe 10 minutes of run time, no boost*
-XS-Power 50mm BOV
-HSP Full 3" Muffler-Less Axle Back system, raw polished stainless
$6945 plus ship. *Can remove some above components, change colors, re-coat, etc and adjust the price if desired*
This sell on our website here: http://shop.huronspeedproducts.com/H...-04-hsct55.htm
for over $11,000 plus shipping with all of the options, components and upgrades.
-Will Include an Eboost 2 (60mm White/Black) with lines for $500 with purchase of kit.
-Alky Control Dual Nozzle C5 Methanol Kit (Twin M15 nozzles, MAP reference)
-Will include my WW Bottle with purchase as well, already set-up. System never used or wired.
$550 with purchase of an above kit
Stock photo of the kit, but shows what all you will be getting!
Kit #1:
-XS-Power 50mm BOV
Kit #2:
-XS-Power 50mm BOV
ss86 (11-21-2020)
Former Vendor
Here are some photos of parts off the vehicles and ready to ship.
We can mix and match parts to get the kit where you want, add/remove parts, change colors, you name it.
If interested in one of the prototype kits for an excellent price, shoot me a PM with what you are looking for and I will cater it to your needs!
other then swapping out the a/c compressor to the included ctsV parts and oil pan any thing else need to be modded on the car? (cut, notched, relocated or hacked?)
how much ground clearance is lost? (if any)
how much HP with the smaller turbos?
Former Vendor
with the smaller turbos and a stock cubic inch engine or close, they will spoil extremely quick and have no problem making 800+ RWHP!
Former Vendor
Dropped the prices! Remember we can mix and match any of the above parts to get a kit where you need it parts and cost wise, PM or email to: Jon@huronspeed.com
Former Vendor
Former Vendor
Prototype kit #2 is pending sale. If interested in one be sure to contact me before they are gone. We can get you set-up with #1 or mix and match with #1 to meet your goals!
