For those of you with the QuickJack lifts, do you use the lifting pucks in the frame slots or just the rubber blocks that come with the lift? I just ordered the 7000SLX model.
I put pucks in place then the rubber blocks, it give you something to aim for and more lift.
I use the rubber blocks. I could not slide the QuickJack under the car with the puks in place. Mine is a Z51 which sits a little lower.
