[C2] Learned a couple of things about '67 repro bolt-ons
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
As I posted awhile back, I threw a starburst and wasn't able to recover it. In the process of replacing it, I learned a couple of things I didn't know, one of which may help some of you keep from losing your starbursts.
1. When my new replacement starburst arrived, the color between the fins was gray, not black like my wheels and other starbursts on my car (see photo). Doing some research, I discovered the early repro bolt-ons had black between the fins. That changed to gray (the color of original KH wheels) in August 2009. Why anyone manufacturing reproduction wheels wouldn't get something as basic as the color right to begin with is beyond my understanding. Anyway, I'll just paint my new starburst fins black like the rest of the car has.
2. I've found 2 loose starbursts over the 3 years I've owned my car. Both had broken retainer clips. I could pull them off by hand. I assume the starburst I lost fell off because of a broken clip. Check out John Hinckley's article below for an explanation as to why this is happening. It all has to do with the lug nuts on the repros being larger than the lug nuts on the original wheels. I'll be pulling all of my starbursts and making sure the flats of the lug nuts are oriented correctly.
https://www.corvetteforum.com/forums...eellugnuts.pdf
BTW, America's Finest Corvettes has a full-page ad in the Sept. - Oct. NCRS Driveline for a new design for mounting starbursts so they can't come off.
Steve
Steve
Received 6,943 Likes
2015 C2 of Year Finalist
BTW AFC have been selling those new caps for at least six years now.
I know this has been discussed before, but it really depends on which ’67 repro wheels you have. I know there have been at least three distinctly different types and probably more. I suspect Steve’s wheels are the early Western Wheel reproductions. The set I had on my car were Corvette America Gen IV wheels and used the standard lug nuts just like the originals and were painted gray. I ran them for five years without a loose starburst.
You're correct, Mike. My wheels say KH Western on the backside. Don't know when they were put on the car. My lugnuts look like these but without the antitheft locking pieces:
http://www.zip-corvette.com/63-67-c2...g-nut-set.html
The only reason I can think that my early repro wheels have black fins instead of the correct gray is that it might have been a copyright or some other intellectual property issue. I mean, if you're trying to reproduce something, you'd certainly want to get the color as close to the ones you're reproducing as you can.
I wish my wheels were the correct color but I don't mind the black and I'm certainly not going to buy new ones. And, yes, I could paint all the fins on all of my wheels the correct gray color but I'm already 70 years old. I don't know if I have enough time left to complete a project of that magnitude . So I'll paint the new starburst fins black and move on. Can't see them when I'm driving down the road anyway.
Steve
Steve:
Original bolt-on wheels used black heat treated clips that were made of a special spring steel. They gripped much tighter than the zinc plated steel ones used for the Western Wheel reproductions.
I use a pliers and set each clip gap at 0.010 inches (4 clips) each time I remove and install a starburst cap. And yes there can be a clearance issue with the lug nuts if you are not careful. JohnZ pointed it out, but I also noticed it from the beginning.
FWIW.
Larry
FWIW.
Larry
Steve:
FWIW.
Larry
FWIW.
Larry
Thanks Larry. I remember you posting about the 0.010 clip gap before and have taken your advice by doing that everytime I take the starbursts off.
I don't suppose those black spring steel clips are available anywhere? I haven't seen them at any of the usual vendors.
Steve
Steve
Steve
You would think someone would duplicate them. They cannot be that expensive. I would gladly pay $$ for a set just to have them.
Larry
