Crate Engines vs Space Claim below C3 Hoods
Old 09-28-2016, 05:00 PM
stormy2503
Support Corvetteforum!
stormy2503's Avatar
Default Crate Engines vs Space Claim below C3 Hoods
Hoping there may be some experience and/or knowledge of a readily available crate engine that will fit below the Std C3 Hood. I am aware of the Edelbrock E-Street 350 CID (PN45080) that will fit using the PN 2701 manifold. Also, as an option, I am looking at the Chev Perf 350 RamJet EFI Crate engine and cannot find any specs or expertise that may offer some info whether this crate will fit below the C3 Stinger Hood. Sort of at a dead end trying to upgrade my anemic L82. Thanks.
Old 09-28-2016, 07:36 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
I dont know if any mfr would guarantee that or if info is available
Ramjet is a nice driver make it fit or cut the hood and glass it up
Old 09-28-2016, 10:06 PM
Jeffs82c3
Jeffs82c3's Avatar
I found this pic of a 350 ramjet in a c3, looks like it fits...
Old 09-28-2016, 11:18 PM
theandies
theandies's Avatar
I'm running a ZZ4 with a Qjet and stock air cleaner. Fits fine under the stock hood.
Old 09-29-2016, 07:46 AM
gdh
gdh's Avatar
I'm running a ZZ383 Deluxe, with the vortec intake it sits high. Even with an L88 hood I needed a drop base air cleaner.
Old 08-01-2017, 03:34 PM
7T9Shark
7T9Shark's Avatar
Default Drop base air cleaner
Where can one find a drop base air cleaner? I'm considering going the 350 Vortec crate route instead of a rebuild.
Old 08-01-2017, 03:42 PM
resdoggie
Had a 1976 L-82, 4-sp
resdoggie's Avatar
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes on 925 Posts
Royal Canadian Navy
Summit.
Old 08-01-2017, 04:44 PM
gdh
gdh's Avatar
Jegs, Summit, really any retail outlet that carries parts should have them.
Old 08-02-2017, 11:02 AM
mobird
mobird's Avatar
The biggest factor is going to be the intake (if it is a standard 350 or 383 small block). If it's a low-rise intake (like the standard Performer style intake) it will fit. If it's one of the taller ones (Air-Gap, Performer RPM, etc...) you will need a drop base air cleaner. What year is your Vette? The later model ones (I believe starting in 78, though someone can correct me if I'm wrong) had a little more hood clearance.
The other factor is your carburetor. Are you using the stock Qjet? If so, make sure the intake is a spreadbore intake so you don't have to use a Carb flange adapter.
To Crate Engines vs Space Claim below C3 Hoods
Quick Reply: Crate Engines vs Space Claim below C3 Hoods
