no power?
Old 09-29-2016, 07:10 PM
olelucky
olelucky's Avatar
Default no power?
i completed engine /trans rebuild and install. did a short test drive, came back made some adjustments. the did another short test drive. after returning i shut it off. now no power. with the key off i have power to the alternator and starter, but when i turn key to run, i lose power to those also. i have power to the left side of the fuse box. none on the right side. no gauges, no lights, no radio
i checked the fusible link near the starter. it had power to both sides(with the key off) what am i missing?
72 350
thanks
Old 09-29-2016, 07:18 PM
BlackC3vette
BlackC3vette's Avatar
Does the starter crank the engine?
Old 09-29-2016, 07:38 PM
olelucky
olelucky's Avatar
No, the starter doesn't even try, no headlights. I did replace starter thinking it may be shorted out. I'm confused on the power going away on the alternator when key is turned to run.
Old 09-29-2016, 08:10 PM
76Rat
76Rat's Avatar
Start with the basics. Check battery terminals and terminal ends to make sure you have good connections (Positive and ground). Sounds like you might have a bad connection somewhere. Its very common with cheap battery terminals
Old 09-30-2016, 06:59 AM
olelucky
olelucky's Avatar
thanks 76Rat and BlackC3vette, I kept checking all the connections and eventually found that the last 5 inches of the battery ground cable where it connects to the frame had corroded within the housing. I replaced the ground cable and everything works great.
Old 09-30-2016, 12:49 PM
BlackC3vette
It's great to see you found the problem. I was going to suggest a voltage drop test on the cables, but you found what I suspected. Good diagnostic work!
To no power?
Quick Reply: no power?
