Whats the Problem??
Whats the Problem??
So I took my '78 L-48 for it's first ride registered today and it didn't go too well. After I filled her up with some 91 I went a few miles and it just died. I got it to start by pop starting it with my dad and then it just kept wanting to die unless I kept giving it gas. Amazingly I then get home and pop the hood and there is gas leaking out of the carb. What could the problem be and what do I need to do to fix it? Thanks!
Could be the carb flooding. Do you notice abnormal amounts of smoke coming from the tailpipes? That would be one clue to flooding. Also were you idling or at speed when it died?
Received 1,468 Likes
Cruise-In II Veteran
Dementer sole survivor
Received 6,278 Likes
2016 C3 of Year Finalist
I agree, fix the leak. Is it leaking from a fuel line, a gasket, pics could help
I agree with 76Vette. Start there. When was the last time the car had a tune up?
Again, however, WHERE are you seeing the "leakage"?
Originally Posted by ballen06
Be very careful...I would advise you to have a fire extinguisher on hand. A leaky carb can cause a fire. Please don't ask me how I know.
Originally Posted by leadfoot4
That's good, BUT you didn't answer the question. WHERE is the fuel "leaking" from? My guess, since it's an older car, is that the float in the fuel bowl is either damaged, causing fuel to get inside of it, so it doesn't "float" and shut off the fuel flow, causing fuel to "spill over", choking out the engine. Or, the float might simply be sticking, due to the inside of the fuel bowl being gummed up, again, causing the float to not work properly.
Having said that, it appears that the carb is original to your car, is quite dirty, probably has some worn parts, and most likely needs a rebuild. Look up Corvette Forum member "Lars". He's the Quadra-Jet guru, here.
FWIW, I've rebuilt several Q-Jets, but it's been over 20 years since I've touched one, so I'm not volunteering, even though you're located somewhat close to me.
That's the 'accelerator pump', and it moves up and down, in conjunction with the accelerator linkage. There's a seal that surrounds that shaft. It's leaking.
From the looks of that carb I wouldn't even try to start that car again before you get a complete rebuild on the carb by someone that knows these carbs . Do it before you have a fire and lose the car .
