Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
coil-over questions
Old 10-16-2016, 06:43 PM
Noveske
Noveske's Avatar
Default coil-over questions
So they are better than the stock leaf springs, by allowing individual wheel control, correct? I was looking at the QA1 setup with 550lb springs. 550lb means 550lbs per inch of compression? Is this setup lighter than the stock leaf? My car is a 2012 GS, 6 speed manual. Any issues with mostly street use, with occasional autocrossing?
Any suggestions as to 450, 550, 650lbs springs?
Am I missing anything? Should I just keep the leaf? I know lots about engines, and nothing about suspension......
Thanks in advance.
Old 10-16-2016, 07:27 PM
c5racr1
c5racr1's Avatar
What are your plans for the car?
Old 10-16-2016, 09:32 PM
Noveske
Noveske's Avatar
mostly corner carving on the street, possibly autocross later next year
Old 10-16-2016, 09:37 PM
c5racr1
c5racr1's Avatar
For street and autocross I would stay on leaf springs and get good shocks. I went from zo6 springs to t1 springs to lg g2 coilovers. I put aero on mine so it's not apples to apples. But I liked the t1 springs with t1 shocks
Old 10-17-2016, 11:24 AM
Matt_27
Matt_27's Avatar
Nope. The leaf springs work exactly the same as coils, individual wheel control is not an issue. I would stay far away from QA1 parts for any sort of performance driving. Koni shocks and stock leaf springs will work much better for you. A larger front sway bar is also a good idea. Those parts and a good set of tires is all you need for some quality autocrossing.
Old 10-17-2016, 03:00 PM
fmcokc
fmcokc's Avatar
Thanks in advance.
Ask Danny Popp, he is a big proponent of the leaf springs and is very fast.
Old 10-17-2016, 03:13 PM
StreetSpeed
StreetSpeed's Avatar
Another vote for the leafs, if it's for street use. The only real reason I went coilovers vs leafs on my race car was to make things easier for the dry sump install.
Old 10-18-2016, 03:04 PM
TKOGTO
TKOGTO's Avatar
Bilstein shocks retaining the leafs will feel significantly better. Coilovers just not necessary for the street.
Old 10-18-2016, 05:49 PM
Noveske
Noveske's Avatar
Thanks for all the replies. Bilsteins it is.
Old 10-18-2016, 07:50 PM
apex26
apex26's Avatar
Default same cost?
Guys, I just got new T1 bars today (1/2 price), so was looking into T1 springs and shocks. LG sells their coilovers for about the same as the T1 leafs and shocks, it seems. Looked and can't find used T1 stuff anywhere. If the cost turns out to be the same for shocks & springs, go LG coilovers? One concern is that I'm close enough to Phoenix, so would get them to set it up, and they're proven experts with the T1 package.
Old 10-19-2016, 09:00 PM
strano@stranoparts.com
Supporting Vendor
strano@stranoparts.com's Avatar
Agree on all of this. My cars, Koni and a Strano 33mm front bar. Leaf springs are actually quite good. Light and offer roll control vs. a coil spring of like wheel rate.
Depending on the model car would likely recommend an upgrade on springs to Hyperco Track front, maybe a track or sport rear (stock might be fine too). But ONLY after you run good shocks and a well chosen sway bar setup to see if you need to bother.
This is the kind of thing I do all day, every day and I'm happy to discuss options with you. I have various things available. KW, MCS, JRZ, Ridetech, QA1 and Viking on the "coil-over" side. Koni, Bilstein, Ridetech on the shock side. I have a lot of sway bar options, including ones I do to my specification. Aside from Strano bars, I have Hotchkis, Pfadt, Eibach, etc.
__________________
Sam Strano
Strano Performance Parts
www.stranoparts.com
814-849-3450
More options than any other single company out there. More parts than any other single company I know: Brakes to Safety, Wheels to Exhaust. Suspension to Air Filters: Girodisc, Hawk, Raybestos, Essex Racing/AP, Ferodo, Wilwood, Penske, Koni, Borg Motorsport, Ridetech, Viking, After Dark Speed, Hotchkis, Bilstein, KW, Forgestar, BC Forged, Forgeline, MRR Wheels and on, and on, and on it goes.
Hole-Shot (11-09-2016)
Old 10-19-2016, 09:02 PM
Supporting Vendor
Should also mention.. I also for a while had a '12 GS myself. And it has a particularly soft front spring/bar combination when compared to the rear. So a front spring change along WITH a front bar change is a good idea if not saddled by rules that keep you from that. If you look to autocross in an SCCA A-Street or SSR class you can't change the front spring legally, and for those cars in particular we offer a bar for just that purpose to help the soft front spring.
Old 10-20-2016, 08:45 AM
Solofast
Solofast's Avatar
Listen to Sam.. He will get you a national level class setup without you having to try to tune it all by yourself.
Unless someone is really experienced in setting up a car and knows what they are doing they are most likely just to make a mess of it and then you'll end up with a car that is not only slow, but it's hard to drive and you'll develop bad habits trying to drive around what is a poor handling car in the first place.
Old 10-22-2016, 10:51 AM
zrtman1
Support Corvetteforum!
zrtman1's Avatar
I had a base C5 with 120k on suspension.. went with LG G2 because I needed shocks and wanted springs for future hpde days. Using the C6 Z51 sways. LG specs them for what your looking to do with them - they are not off the shelf - they are built to order. Biggest thing for me is if I want to do something different in the future I can have them re valved and change spring rates if needed. I think I am running a 800 front spring but it rides pretty decent and is fun at VIR and CMP. Rides wayyy better than my old C4 with Z07 package. Bolt on and go - no thinking. Lg is very good if you have questions...
Old 10-22-2016, 12:01 PM
l98tpi
Max G’s
l98tpi's Avatar
I've had good service out of QA1 shocks. I have ran the double adjustables on my C4 for 3yrs without issue.
Old 10-26-2016, 11:40 AM
SargeZ06
SargeZ06's Avatar
Sam
Whats a better upgrade for stock suspension? Bar or shocks?
Alignment is Fr:Camber -2.55, caster 6.58, Toe -.16. Rear: Camber -1.28, toe 0.28.
I drive the car at it's limit. I've talked to you a while back before this alignment about Bilsteins and you had me focus on the alignment. Car drives 100% better with these numbers.
Center to exit just starting to roll into throttle:
Old 10-26-2016, 03:23 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Phoenix is a dealer of ours and I would imagine Joe would hook you up with both parts and install if you wanted them to.
Old 10-26-2016, 06:58 PM
apex26
apex26's Avatar
That's good to know because Phoenix needs to corner balance and align it anyway.
Old 11-02-2016, 09:30 AM
conradb
conradb's Avatar
Definitely go with new dampers on leaf springs for your applications. I only just last month switched to aFe Johnny O'Connell coilovers for track work after working my way up over a year for road racing.
Might I recommend Doug Rippie's custom-valved Bilstein dampers? I actually have my old set if you're interested in buying them only ~6mo used. Send me a PM.
To coil-over questions
Quick Reply: coil-over questions
